    Bed Leveling G32 or G29
    1.3k
    • Karimundefined
      Karim
      Hey guys I have two Z 2:6 I set up bed.g like this below. G32 get me this Error: Bad command: :called to perform automatic bed compensation via G32, follow by this Leadscrew adjustments made: 0.005 0.008, points used 2, deviation before 0.007 after 0.000. I am trying to figure which one to use G32 or G29 or can I use both. I comment out M561 and G29 .
      ; bed.g
      ; generated by RepRapFirmware Configuration Tool v2 on Mon Dec 10 2018 01:47:39 GMT+0000 (GMT)
      G28 ; home
      G30 P0 X0 Y210 Z-99999 ; probe near a leadscrew
      G30 P1 X375 Y210 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
      ;M561 ; clear any bed transform
      ;G29 ; probe the bed and enable compensation
      Thank You
        dc42 administrators @Karim
        @karim said in Bed Leveling G32 or G29:
        That line should start with a semicolon, not a colon. Try this:
        ; bed.g
        G28 ; home
        Or you can use G29 S1 at the end instead of G29 if you want to load a previously-stored height map.
        • Karimundefined
          Karim
          G32
          Leadscrew adjustments made: 0.054 0.033, points used 2, deviation before 0.045 after 0.000
          25 points probed, mean error 0.011, deviation 0.482
          Height map saved to file heightmap.csv
          How does this look.
          • Karimundefined
            Karim
            I try re level the bed and get this now, what do you guys see.
            G32
            Leadscrew adjustments made: -0.205 0.154, points used 2, deviation before 0.181 after 0.000
            25 points probed, mean error 0.049, deviation 0.151
              Looking better. What is your probe? You can try increasing the A value of M558 to try and get more consistent values from the probe points.
              You could increase the probe point density further to see how the bed shape varies more closely.
              • Karimundefined
                Karim
                MINI DIFFERENTIAL IR HEIGHT SENSOR
                https://www.filastruder.com/collections/electronics/products/mini-differential-ir-height-sensor
                How can I get better resolution. What do you mean by (You can try increasing the A value of M558)
                M574 Z0 S2
                M558 P1 H5 F120 T6000
                G31 P500 X0 Y0 Z2.493
                M557 X30:375 Y50:390 S82
                  Phaedrux Moderator @Karim
                  @karim https://duet3d.dozuki.com/Wiki/GCode#Section_M558_Set_Z_probe_type
                  The A and S parameters control multiple probing. Probing is repeated until two consecutive probe attempts produce results that differ by no more than the S parameter; then the average of those two results is used. However, if the number of attempts specified by the A parameter is reached without getting two consecutive results within tolerance of each other, no further probe attempts are made and the average result of all the attempts is used.
                  For instance, I use M558 A10 S0.005 with my BLTouch
                  • Karimundefined
                    Karim
                    I don't know what to change , I hope dc42 can answer this.
