    Hotend crashes after print was stopped and started again.
    IR Height Sensor
    663
    • Sushiator
      Sushiator last edited by
      Hello there!
      I got my DC42 configured and running great, the Documentation is really great.
      However, i can't get that thing working properly after i cancelled a print.
      After Startup the Autohome works just fine, i soon start a print and maybe smth. goes wrong, so, cancelling the print is a great option, and starting over again as soon as possible. But the the Z-Homing fails, the LED switches on, the Z-Motors stop for a moment, and start to lower very slowly again, until the Hotend crashes into the bed.
      After pressing the E-Stop and rebooting the Board even the first Autohome wont work, with the same problem as mentioned above. Only hard-resetting the Duet will fix this Issue, until the next time smth. goes wrong.
      Firmware ist 2.02, Wifi 1.22 and Interface 1.22.6
      Here is my Z-Probe Config:
      M574 Z1 S2
      M558 P1 H5 F120 T6000
      G31 P536 X0 Y-25 Z3.07
      M557 X30:260 Y5:270 S30
      i hope i didn't miss anything in the config, as a noob in reprap fw.
      Thanks in advance!
        Can you post your config.g, homing files, and your pause.g and cancel.g files? It's impossible to know what's going on without seeing those.
        • Sushiator
          There you go:
          Config.g:
          M92 X80.00 Y80.00 Z400.00 E95.00 ; Set steps per mm
          M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
          M203 X24000.00 Y24000.00 Z240.00 E1500.00 ; Set maximum speeds (mm/min)
          M201 X500.00 Y500.00 Z20.00 E250.00 ; Set accelerations (mm/s^2)
          M906 X800.00 Y800.00 Z800.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
          M84 S10 ; Set idle timeout
          M208 X-10 Y-30 Z0 S1 ; Set axis minima
          M208 X300 Y300 Z400 S0 ; Set axis maxima
          M574 X1 Y1 S0 ; Set active low and disabled endstops
          M558 P1 H5 F120 T6000 ; Set Z probe type to unmodulated and the dive height + speeds
          G31 P536 X0 Y-25 Z3.195 ; Set Z probe trigger value, offset and trigger height
          M557 X30:260 Y5:270 S30 ; Define mesh grid
          ; Heaters Hotend
          M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
          ;Heaters Bed (Disabled)
          M140 H-1
          M106 P1 S0 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
          M106 P2 S1 I0 F500 H1 T40 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
          M563 P0 S"V6 Gold" D0 H1 F0:1 ; Define tool 0
          ; Automatic power saving
          M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
          T0 ; Select first tool
          Homeall.g:
          ; called to home all axes
          ; generated by RepRapFirmware Configuration Tool v2 on Sat Jan 12 2019 17:27:47 GMT+0100 (Mitteleuropäische Normalzeit)
          G91 ; relative positioning
          G1 S1 X-315 Y-335 F2400 ; move quickly to X and Y axis endstops and stop there (first pass)
          G1 X5 Y5 F6000 ; go back a few mm
          G1 S1 X-315 Y-335 F360 ; move slowly to X and Y axis endstops once more (second pass)
          G90 ; absolute positioning
          G1 X30 Y30 F6000 ; go to first bed probe point and home Z
          ;G91 ; relative positioning
          ;G1 S2 Z5 F100 ; lift Z relative to current position
          ;G90 ; absolute positioning
          Homez.g:
          ; homez.g
          ; called to home the Z axis
          G1 X30 Y30 F6000 ; go to first probe point
          Pause.g:
          ; called when a print from SD card is paused
          M83 ; relative extruder moves
          G1 E-10 F3600 ; retract 10mm of filament
          G1 Z5 F360 ; lift Z by 5mm
          G1 X0 Y0 F6000 ; go to X=0 Y=0
          Cancel & Stop.g are empty...
            Hmm, try creating a cancel.g file with something in it. Maybe turn the heaters off and Home XY just so there is something in it.
            Also, is there something in your slicer start gcode that might be changing anything?
            • Eddiie
              Eddiie last edited by
              There was a bug fix in the latest release related to stop/start (pause / resume).. I was having the same problem and the new release fixed it. (I think it was fixed in 2.02 RC6; see release notes)
              Currently I am on -
              Firmware Version: 2.02RC6(RTOS) (2018-12-15b2)
              WiFi Server Version: 1.21
              Web Interface Version: 1.22.5
              • Sushiator
                My Firmware is the Newest from Github: 2.02(RTOS) (2018-12-24b1)
                I Can't remember if i had that problem prior to the FW Update, i'am pretty new in the Duet world.
                  dc42 administrators @Eddiie last edited by
                  @eddiie said in Hotend crashes after print was stopped and started again.:
                  That bug was only present in 2.02RC5.
                    @Sushiator, two suggestions:
                    1. One thing that often catches people out is that if you don't have a cancel.g file, the firmware will de-select the current tool when you cancel a print. Then when you try to print again, there is no tool selected. This is a problem if you were relying on a tool being already selected when you start a print (you may have included a T0 command near the end of config.g to achieve that after power up).
                    However, I don't see how not having a tool selected would cause probing to fail, unless you have something unusual in your tfree0.g file.
                    1. After cancelling a print, send M558 without parameters and check whether the reported parameters are the same as you set in config.g.
                    • Sushiator
                      I already have that T0 Command in my Config, so i could have both print cooling fans as "Tool Fans" right after Startup.
                      Gonna check that M558 the next time i screw smth up.
                      Oh, and keep up the good Work, great piece of Hardware you made there!
