    Dual Z-axis endstops
    89
    20.1k
    • j3dkundefined
      j3dk
      @j3dk:
      I have have an FT-5 and want to split my Z axis when homing, my Home Z.g looks like this:
      ; homez.g
      ; called to home the Z axis
      ; generated by Jens Kej on Sun Mar 11 2018 15.00
      G91 ; relative mode
      G1 Z4 F200 ; raise head 4mm to ensure it is above the switch trigger height
      G90 ; back to absolute mode
      G1 X-305 Y-305 F1800 S1; move XY home
      G1 X150 Y150 F2000 ; put the head to be centered when you home Z
      G91 ; relative mode
      M584 Z2 U3 ; split Z axis in two
      G1 Z-400 U-400 S1 F100 ; home the Z- and U axis
      G92 Z0.1 ; tell the software that it 0,1 mm above bed
      M584 Z2:3 ; make One Z axis again
      the bed is moving fine up and down from web interface but only the Z axis is trying move when I push home Z, why?
      here comes my config.g:
      ; Configuration file for Duet WiFi (firmware version 1.17)
      ; generated by Jens Kej on Thu Sep 21 2017 17:16:32 GMT+0200 (Rom, sommertid)
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M208 X300 Y300 Z350 S0 ; Set axis maxima
      ;M574 Z1 S1 ; Define Hall sensor active high on Z-axis
      M574 X1 Y1 Z1 U1 S0 ; Define active low and unused microswitches
      :M558 P1 X0 Y0 Z0 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
      ;G31 P600 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
      ;M557 X15:285 Y15:285 S20 ; Define mesh grid
      M569 P0 S0 ; Drive 0 goes backwards
      M569 P4 S1 ; Drive 4 goes forwards
      M569 P5 S1 ; Drive 5 goes forwards
      M569 P6 S1 ; Drive 6 goes forwards
      M584 X0 Y1 Z2:3 U3 E4:5:6 P3; Apply custom drive mapping
      M350 X16 Y16 Z16 U16 E16:16:16 I1 ; Configure microstepping with interpolation
      M92 X80 Y80 Z400 U400 E100💯100 ; Set steps per mm
      M566 X900 Y900 Z12 U12 E120:120:120 ; Set maximum instantaneous speed changes (mm/min)
      M203 X6000 Y6000 Z1000 U1000 E1200:1200:1200 ; Set maximum speeds (mm/min)
      M201 X500 Y500 Z250 U250 E250:250:250 ; Set accelerations (mm/s^2)
      M906 X800 Y800 Z800 U800 E800:800:800 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M143 S260 ; Set maximum heater temperature to 260C
      M305 P0 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 0
      ;M305 P1 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 1
      M305 P1 x151 ; Thermocouple
      M307 H1 A626.6 C265.6 D13.9 ; hotend pid settings
      M563 P0 D0 H1 ; Define tool 0
      M563 P1 D1 H1 ; Define tool 1
      G10 P1 X0 Y0 Z0 ; Set tool 1 axis offsets
      G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
      M563 P2 D2 H1 ; Define tool 2
      G10 P2 X0 Y0 Z0 ; Set tool 2 axis offsets
      G10 P2 R0 S0 ; Set initial tool 2 active and standby temperatures to 0C
      M550 PFT-5 DD ; Set machine name
      M552 S1 ; Enable network
      M587 Sfarce95taske53lufffe P"be81b0f702d6d23152c28d870e" ; Configure access point. You can delete this line once connected
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M106 P0 S1 I0 F500 H1 T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M501 ;Load overide config.g
      Jk
        Your two M208 commands need to be moved to be after the M584 command, and you need to add U axis values to them.
        • j3dkundefined
          j3dk
          @dc42:
          I made something very wrong, messed it all up and had to put new configuration files on the SD-Card. Then I started all over again from scratch. Now my config.g and homez.g looks like this, much better structured, without unused comands etc. but the problem still remains the same:
          ; config.g Dual Z-axis
          ; generated by RepRapFirmware Configuration Tool on Mon Mar 19 2018 17:18:48 GMT+0100 (Rom, normaltid)
          ; Edited by J. Kej on Mon Mar 19 2018 20:58:48 GMT+0100 (Rom, normaltid)
          M550 PJK'S FT-5 DD ; Set machine name
          M587 S"farce95taske53lufe" P"be81b0f702d6d23152c28d870e" ; Configure access point.
          M586 P1 S1 ; Enable FTP
          M586 P2 S1 ; Enable Telnet
          M584 X0 Y1 Z2:3 U3 E4:5:6 P3 ; Configure drive remapping to dual Z-axis
          M350 X16 Y16 Z16 U16 E16:16:16 I0 ; Configure microstepping without interpolation
          M203 X6000 Y6000 Z1800 U1800 E1200:1200:1200 ; Set maximum speeds (mm/min)
          M208 X0 Y0 Z0 U1 S1 ; Set axis minima
          M208 X300 Y300 Z350 U350 S0 ; Set axis maxima
          M574 X1 Y1 Z1 U1 S0 ; Set active low endstops
          M558 P0 H3 F120 T6000 ; Disable Z probe but set dive height, probe speed and travel speed
          M305 P1 X151 ; Configure thermocouple for heater 1
          G10 P0 X0 Y0 Z0.1 ; Set tool 0 axis offsets
          G10 P1 X0 Y0 Z0.1 ; Set tool 1 axis offsets
          G10 P2 X0 Y0 Z0.1 ; Set tool 2 axis offsets
          M563 P3 D0:1:2 H1 ; Define tool 3
          G10 P3 X0 Y0 Z0.1 ; Set tool 3 axis offsets
          G10 P3 R0 S0 ; Set initial tool 3 active and standby temperatures to 0C
          M568 P3 S1 ; Enable mixing for tool 3
          M567 P3 E0.33:0.33:0.34 ; Set mixing ratios for tool 3
          ; Custom settings
          ; homez.g
          ; generated by RepRapFirmware Configured for Dual Z-axis by J. Kej on Mon Mar 19 2018 20:18:47 GMT+0100 (Rom, normaltid)
          M584 Z2 U3 P3
          G1 S1 Z-355 U-355
          G92 Z0.1
          M584 Z2:3 P3
          Jk
            Have you tested the U endstop switch? Perhaps it is showing as already triggered. See https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Test_endstop_switches.
            • j3dkundefined
              j3dk
              @j3dk:
              @dc42:
              ; Custom settings
              ; homez.g
              M584 Z2 U3 P3
              G1 S1 Z-355 U-355
              G92 Z0.1
              M584 Z2:3 P3
              Endstop Z and U are working properly, led's on board lights up when i hit them with my finger. That's not the issue…...
              Jk
                Can you see the U endstop working in the Duet Web Control Machine Properties page? The LED is not always a reliable indication.
                • j3dkundefined
                  j3dk
                  @dc42:
                  Found out that U endstop is not working and it seems like it is a problem related to my Duet WiFi board as I have tested/measured all wires, connectors and endstops, yhey are all ok.
                  Then I have tried to move the plug from my working Z stop to the U connector on the board but when I turn it on again and go to Machine Properties page nothing works.
                  Now I also have tried to move the stepper and endstop for my U axis to E4 on my duex5 and remap U in my confiig.g and homez.g but I still had the same problem.
                  Have tested all my endstops and they work properly on the XYZ axis. On all other they seem to work the oposite way in the machine properties page. Reported as hit and change from Yes to No when I hit them manually, Whats wrong then?
                  Jk
                    1. If you are running firmware 1.21RC5 then it's normal for endstops that are set to active low to read the wrong way round. That's fixed in the 1.21 release.
                    2. Are you using microswitches, or some other type of endstop?
                    3. Please run M574 without parameters, and check that the U endstop is reported as being configured the same way as XYZ.
                    • j3dkundefined
                      j3dk
                      1. Now I have updated my Firmware to ver. 1.21 and now all my declared endstops works, but still no readings of minimum and maximum for drive 3 aka U axis.
                      2. I use standard Makerbot Mechanical endstops ver. 1.2
                      3. M574 returns: Endstop configuration: X: low end active low switch, Y: low end active low switch, Z: low end active low switch, U: low end active low switch,
                      Now when I try to move Z up and down I get a red popup like this:
                      M120
                      G91
                      G1 Z-1 F6000
                      M121
                      Error: G0/G1: insufficient axes homed
                      Error: Pop(): stack underflow!
                      homez still don't work
                      What's next?
                      Jk
                        Read the release notes for firmware 1.21.
                        • j3dkundefined
                          j3dk
                          all should now be updated and I have read the release notes.
                          I'm homing X and Y fine but trying to home Z, my homez.g looks like this:
                          G91 ; relative positioning
                          M584 Z2 U3 P3
                          G1 S1 Z-355 U-355
                          G92 Z0.1
                          M584 Z2:3 P3
                          G90 ; absolute positioning
                          but only the spindle connected to the Z connector is trying to home but noting happens on U spindle. My machine properties looks like this:
                          Logical Drive Endstop hit Minimum Maximum InstantDv Max Speed Acceleration Motor Current
                          X Yes 0 mm 300 mm 15 mm/s 100 mm/s 500 mm/s² 800 mA
                          Y Yes 0 mm 300 mm 15 mm/s 100 mm/s 500 mm/s² 800 mA
                          Z No 0 mm 350 mm 1 mm/s 30 mm/s 250 mm/s² 800 mA
                          E0 No n/a n/a 1 mm/s 30 mm/s 250 mm/s² 800 mA
                          E1 Yes n/a n/a 2 mm/s 20 mm/s 250 mm/s² 800 mA
                          E2 Yes n/a n/a 2 mm/s 20 mm/s 250 mm/s² 800 mA
                          I can now see that endstop for Z works, the one I have set for U now works on E0 and my E3 no longer exists.
                          My parameters set for the U seems to be in E0 row but no min and max values are available here. I guess that's why my U axis can't move. What can I do to solve this?
                          Jk
                          • j3dkundefined
                            j3dk
                            I have the following software information:
                            Firmware Electronics: Duet WiFi 1.02 or later + DueX5
                            Firmware Version: 1.21 (2018-03-21)
                            WiFi Server Version: 1.21
                            Web Interface Version: 1.21-RC4
                            Jk
                              Try changing P3 in this line of homez.g:
                              M584 Z2 U3 P3
                              to P4, so that U is treated as a real axis during homing.
                              • j3dkundefined
                                j3dk
                                Thanks now Z and U is homing. Back to work…...
                                Jk
                                • andymidtfundefined
                                  andymidtf
                                  Hi David,
                                  I'm having basically exactly the same issue as j3dk: 2 independent z-axis motors, 2 z-axis endstops, when homing only moves 1 z-axis, the Z... the U just looks at me and laughs... when homing X and Y, and once homed Z, both z-axis move correctly, so I am sure it is something wrongly configured...
                                  After following thru all this thread, I finally realised that my Machine Properties for E0 and E1 are reversed, E0 is my extruder, and E1 is my right hand z-axis, what I have declared as U in my config.g - the endstops themselves do correspond to the correct axis, but the rest of the values of E0 are the same as Z, whilst the values of E1 are those that I have configured for the extruder.
                                  I have tried changing the remap command so E is before U, but seems to have no effect - flash! should I also rearrange all the other parameters too?
                                  Attach config.g and homez.g, although especially homez, I have revised it at least 5 times as I have gone thru this thread!
                                  Thanks!
                                  Andy
                                  0_1523477320088_config copy.g
                                  0_1523477329606_homez.g
                                    I don't know how you manage to move any axes at all, because the only M906 command I see in your config.g is this one:
                                    M906 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent\
                                    so all the XYZU motor currents will be zero.
                                    andymidtfundefined 1 Reply Last reply Reply Quote 1
                                      andymidtf @dc42
                                      @dc42 sorry! forgot to mention, I'm using external stepper drivers for XYZU! 😉
                                      I am fond of removing surplus code, so after somewhere in the wiki I saw something about the external drivers are the ones that actually decide the current and microsteps, I removed all M350 and M84 that referred to the external drives - works perfectly for all moves as-is - it is just the homing that only 1 z-axis does not want to cooperate!
                                      Cheers!
                                      Andy
                                      • AlexLinundefined
                                        AlexLin
                                        Probably noob question.. But I assume you need to tune both Z ends top flags so Z and U line up correctly.is that more more accurate than using the Z-Probe method? Or is dual end stop better since you also can sync after power failure. If you have them both as max endstops, that is
                                        dc42undefined andymidtfundefined 2 Replies Last reply Reply Quote 0
                                          dc42 administrators @andymidtf
                                          @andymidtf said in Dual Z-axis endstops:
                                          Cheers!
                                          Andy
                                          Of course, for some reason I had the idea that you were using a DueX5.
                                          • Does DWC display the U axis?
                                          • Are you able to jog the U axis by small amounts?
                                          • If you send M208 without parameters, does it report the correct U axis limits (same as Z axis)?
                                            dc42 administrators @AlexLin
                                            @alexlin said in Dual Z-axis endstops:
                                            Yes syncing after power failure could be an advantage of dual Z endstops. As for accuracy, I don't have a machine with dual Z leadscrews so I can't compare them.
