After firmware 2.02RC7 custom PanelDue stops work
Hello. My friend presented me Duet Ethernet. I havent money so im by my self converted it to Duet Wifi by soldering ESP8266 on board. Works greate. Than i take my not used Mks TFT and flash it with fork of paneldue from here https://github.com/robotsrulz/MKS-TFT . Works greate. But when im update firmware of board to last version. My lcd want connect. How to fix it? Im havent money to buy original paneldue((
I assume you have not changed your config.g file.
I suggest you ask the author of that fork of PanelDueFirmware if it has been tested with recent RRF firmware. There are some additional fields in the M408 status response now, and it may be that the fork of PanelDueFirmware you are using can't handle the response any more because of its extra length.
Can you explain what you change. Im edit firmare to fix error. Thnx!
I'm sorry, I can't tell you because I am not familiar with that fork of PanelDueFirmware. I didn't need to make any changes to the master PanelDueFirmware to make it work versions of RRF after 2.07.
Ok. Im fixed it. It would be very good if you could help me finish porting the code and put it in order. At the moment, almost everything works, except for printing from USB flash drives. This firmware can turn the popular MKS TFT display into a multifunctional PanelDUE.
