    Heater 0 has burned
    • andersondpasqualiundefined
      andersondpasquali
      Heater 0 has burned out how do I set the heater 1 and set it as heater 0 ??
        When you say "Heater 0 has burned", do you mean the bed heater output or the E0 heater output? Which Duet is it?
        It's highly unusual for the heater circuits of genuine Duets to burn out, except that the terminal blocks will burn out if the clamping screw doesn't stay tight.
