    Duet sometimes does not start to print after heatup
    • crynoolundefined
      crynool
      Hey,
      I'm facing the problem, that sometimes after heating up, the printer just idles, doing nothing.
      It is connected via Network and print is controlled via USB (Simplify3D).
      The M117 command at the end of my starting script is seen in the Webinterface, but cannot recall to see it on the PanelDue.
      Here is the starting code, the M122 and the config.g
      Maybe another set of eyes can point me to a place...
      I know in the heat up section, there is the M140 for the Bed followed by M116, then the G10 for the heater follower by another M116.
      I want to have it in a sequence, not heating up in parallel.
      I have the impression, with the old style code for setting the temperature (was it M190) it did not happen.
      Enabling the 'Verbose Output' in Simplify3D after the printer idles does not show any output. M122 was run during the idle state, so at least there was a response from the Duet.
      No Entry in the event log, debugging not enabled.
      G90
      M82
      M106 S0
      M80 ; Enable Power
      M140 S-273.15 ; Switch Bed off
      G10 P0 R-273.15 S-273.15 , Switch heater off
      G28 ; home all axes
      G29 S1 ; Load Mesh
      G1 X0 Y0 Z5 F4000 ; Move closer to the Bed
      G4 S1 ; Pause
      G30 ; Single Probe
      G0 X0 Y100 Z10 F4000 ; Get out of my way
      M140 S60 ; get bed heating up
      M116 ; and wait
      G10 P0 S210 R60 ; set extruder temp
      M116 ; and wait
      M400 ; clear buffer
      G4 S1 ; pause
      M117 Gettin' it on... ; LCD status message
      ; process PLA - Silk Copper
      ; layer 1, Z = 0.100
      T0
      G92 E0.0000
      G1 E-6.5000 F6600
      ; feature skirt
      ; tool H0.200 W0.400
      G1 Z0.300 F1200
      G1 X-14.382 Y22.043 F9000
      G1 Z0.100 F1200
      G1 E0.2000 F6600
      G92 E0.0000
      G1 X-19.190 Y22.370 E0.1603 F900
      G1 X-21.407 Y21.591 E0.2385
      G1 X-22.204 Y21.398 E0.2657
      G1 X-23.476 Y20.930 E0.3108
      G1 X-24.292 Y20.520 E0.3412
      G1 X-24.545 Y20.643 E0.3505
      G1 X-24.864 Y20.786 E0.3622
      G1 X-25.501 Y21.051 E0.3851
      12:24:30 PMM122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet Ethernet 1.02 or later
      Board ID: 08DGM-95BLL-N6PSS-6JKD0-3S46R-9JSML
      Used output buffers: 1 of 20 (16 max)
      Static ram: 25524
      Dynamic ram: 98332 of which 0 recycled
      Exception stack ram used: 456
      Never used ram: 6760
      Tasks: NETWORK(ready,648) HEAT(blocked,1232) MAIN(running,3860) IDLE(ready,200)
      Owned mutexes:
      Last reset 02:59:55 ago, cause: software
      Last software reset at 2019-01-18 09:24, reason: User, spinning module GCodes, available RAM 6696 bytes (slot 1)
      Error status: 0
      Free file entries: 9
      SD card longest block write time: 3.9ms, max retries 0
      MCU temperature: min 29.6, current 37.0, max 42.6
      Supply voltage: min 0.4, current 24.3, max 24.5, under voltage events: 4, over voltage events: 0, power good: yes
      Driver 0: standstill, SG min/max 0/186
      Driver 1: standstill, SG min/max 1/238
      Driver 2: standstill, SG min/max 0/158
      Driver 3: standstill, SG min/max 0/1023
      Date/time: 2019-01-18 12:24:26
      Slowest loop: 15.20ms; fastest: 0.06ms
      I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
      Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 120, MaxWait: 9490025ms, Underruns: 0, 0
      Scheduled moves: 7792, completed moves: 7792
      Bed compensation in use: mesh
      Heater 0 is on, I-accum = 0.1
      Heater 1 is on, I-accum = 0.3
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 7.33ms; fastest: 0.02ms
      HTTP sessions: 1 of 8
      Interface state 5, link 100Mbps full duplex
      ; Configuration file for Duet Ethernet (firmware version 1.20 or newer)
      ;M0 ;Power off & everything
      M665 L288.160 R140 H285 B120.0 X0 Y0 Z0.000 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 A0 B0 ; Put your endstop adjustments here, or let auto calibration find them
      M569 P0 S0 ; Drive 0 goes backwards
      M92 X80 Y80 Z80 E476.55 ; Set steps per mm -> BONDTECH DEFAULT: 476.55
      M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min)
      M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)
      M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)
      M906 X1200 Y1200 Z1200 E1300 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 Z0 S1 ; Set minimum Z
      M574 X2 Y2 Z2 S1 ; Set active high endstops
      ; Z probe and compensation definition
      M558 P8 R0.4 T10000 F800 H3 A1 S0 B1
      G31 P999 X0 Y0 Z-0.24
      M557 R100 S25 ; Setup Mesh Bed Compensation grid. R: Mesh Radius, S: Cell Size
      ; >>>> Bed ----------------------------------------------------------------------------------------
      M305 P0 T100000 B3950 R4700 H0 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
      ; >>>> Hotends ------------------------------------------------------------------------------------
      M305 P1 T100000 B4388 R4700 H0 L0 -
      M143 H0 S120 ; Set temperature limit for heater 0 to 85C
      M106 P1 T60 S1 H1 C"Hotend" ; Set fan 1 value
      M106 P2 I0 F100 H100:101:102 T50 C"Board" ; Set fan 2 value
      M563 P0 D0 H1 ; Define tool 0
      ; Automatic power saving
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
      M562 ;Reset Heater Faults
      M912 P0 S-9 ;CPU Temp Calibration Offset
      T0
      M929 P"eventlog.txt" S1 ; start logging to file eventlog.txt
        One problem that may cause prints not to work is not having a T0 command at the start of the GCode file you are trying to print. the T0 in your config.g file will mean that the first print will work, but subsequent prints might not if tool 0 is deselected when the print finishes or is cancelled.
        We recommend that you upload the file produced by S3D to the SD card, and print from SD card. You can automate uploading from S3D, see https://forum.duet3d.com/topic/867/duet-wifi-s3d/14.
        • crynoolundefined
          crynool
          Thanks for the reply.
          I checked both of my config.g and the .gcode, as well as the additional starting script for the T0 and it was always there, not only in the config.g
          I tried to put it into several places, had T-1 in the ending script, beginning of the start script a T-1 followed by a T0, just played around a bit.
          When I use this sequence:
          M140 S[bed0_temperature] ; get bed heating up
          M116 H0 ;wait for bed heater
          G10 P0 S[extruder0_temperature] R60 ; set extruder temp
          M116 P0 ; and wait for extruder
          T0 ; Activate Tool 0
          It waits for the bed to heat up, then the tool becomes active, started heating and moving, not waiting until the hotend reached its temperature:
          Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
          Even if I try the M116 without additional parameter, it does the same when I have the T0 after the heating section.
          If I have the T0 before the section, every print which is not the first print after a reset waits forever.
          I have multiple printers (not all Duet based), so I prefer to use my old way of working.
          If this is a feature I have to deal with it, but maybe it is not ... 🙂
            The T0 command needs to be before the M116 command, because tool heating does not start until the tool is selected.
