    upload gcode error
    983
    • deltajegga
      deltajegga last edited by
      ive been uploading and printing fine for the past few days except once in a while it would upload really slow, and then it would fail one here and there.
      now it fails every time.
      just updated the firmware, wifi module, and the DWC.
      running on win7 google chrome
      i also removed the card and checked for errors and defragmentation was at 0%.
      ive only ran about 20 files through it so far.
      i can connect and move the printer fine i just cant upload anything via wifi.
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.02 or later
      Board ID: 08DGM-9T6BU-FG3S0-7JKD4-3S86J-1A5ZF
      Used output buffers: 3 of 20 (10 max)
      Static ram: 25524
      Dynamic ram: 98532 of which 0 recycled
      Exception stack ram used: 328
      Never used ram: 6688
      Tasks: NETWORK(ready,408) HEAT(blocked,1176) MAIN(running,3844) IDLE(ready,200)
      Owned mutexes:
      Last reset 00:17:22 ago, cause: power up
      Last software reset at 2019-01-17 23:36, reason: User, spinning module GCodes, available RAM 6688 bytes (slot 3)
      Error status: 8
      Free file entries: 10
      SD card longest block write time: 186.3ms, max retries 0
      MCU temperature: min 23.1, current 26.5, max 26.7
      Supply voltage: min 23.9, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
      Date/time: 2019-01-18 13:26:23
      Cache data hit count 3888618574
      Slowest loop: 9.89ms; fastest: 0.07ms
      I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
      Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
      Scheduled moves: 0, completed moves: 0
      Bed compensation in use: none
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 1345.29ms; fastest: 0.00ms
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is running
        WiFi firmware version 1.22
        WiFi MAC address 84:f3:eb:42:aa:fe
        WiFi Vcc 3.42, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 25936
        WiFi IP address 192.168.1.104
        WiFi signal strength -66dBm, reconnections 0, sleep mode modem
        dc42 administrators @deltajegga last edited by
        @deltajegga said in upload gcode error:
        That's rather a long block write time, so the problem might be wear on the SD card. Try a new SD card, and make sure you format it using 32kb or 64kb cluster size.
        That signal strength is a little lower than ideal, but probably OK.
        • deltajegga
          so i reformatted an sd card i had sitting but i think that made it worse, it says my wifi module is connected to the network but DWC wont connect. im gonna buy a fresh card today and try again. all i should need to do is just copy the files from the old one to the new card right? and keep the directory's the same.
            dc42 administrators @deltajegga last edited by dc42
            Correct.
            If you are using a 2.0RC version of DWC then I suggest you revert to DWC 1.22.6. I get occasional upload errors using DWC 2.0RC3, whereas uploads are 100% reliable using DWC 1.22.6.
            • deltajegga
              okay i got a sandisk ultra 16g, formatted to 64kb and tried an upload.
              it tried for 20 mins and got up to like 90% and failed. ill try reverting to 1.22.6 later tonight. i dont understand how it worked at first but slowly got worse. ill try scooting it closer to the router to be sure.
              • deltajegga
                deltajegga last edited by deltajegga
                ok so i just took the time to actually look, haha, and i am already on DWC 1.22.6
                should i try updating to dwc2?
                  No, I find DWC 1.22.6 completely reliable, but DWC2 not yet.
                  I am guessing that the problem is related to signal strength or WiFi interference. See https://duet3d.dozuki.com/Wiki/WiFi_disconnections_and_AJAX_timeout_errors. Note, a small number of WiFi routers seem to be incompatible with the ESP WiFi modules. We don't know why.
                  • deltajegga
                    ill try moving it closer. is there anything else that you think would cause it to slowly degrade?
                      It could be that the 2.4GHz spectrum has become more congested where you are. Changing WiFi channel on your router may help.
                      • deltajegga
                        This post is deleted!
