BlTouch were G30 is working but G29 are not
  • I have a Duet 2 Wifi that are running my Tronxy x5s 3d printer (CoreXY). It has dual Z-axis were the second is run with the extra extruder driver and E0 pin for its own end stop.
    I have followed the tutorial on how to set up the BLTouch.
    When given the "G30 S-1" it works perfectly. But once i call the "G29" for mapping of the bed it just slams the bed into my hotend and endstops (with high speeds i should add ☹ ).
    Does anyone have a clue what i am doing wrong? I am suspecting that it might have something to do with my dual z endstops?
    Any help will be appreciated, thanks ☺
    ____ Firmware_____
    Firmware Version: 2.02RC6(RTOS) (2018-12-15b2)
    WiFi Server Version: 1.21
    Web Interface Version: 1.22.5
    config file__
    ; generated by RepRapFirmware Configuration Tool on Mon Jul 23 2018 19:43:29 GMT-0500 (Central Daylight Time)
    M667 S1 ; Select CoreXY mode
    M550 PTronxy X5S ; Set machine name
    M552 S1 ; Enable network
    M587 S"HomeBox-5240_2.4G" P"hg39gg72b" I192.168.1.187 J192.168.1.1 K255.255.255.0 ; Configure access point and IP addresses. You can delete this line once connected
    M586 P0 S1 ; Enable HTTP
    M586 P1 S0 ; Disable FTP
    M586 P2 S0 ; Disable Telnet
    M208 X0 Y0 Z0 U0 S1 ; Set axis minima
    M208 X330 Y330 Z380 U380 S0 ; Set axis maxima
    ;DUAL Z
    M584 X0 Y1 Z2:3 U3 E4 P3
    M574 X1 Y1 Z1 U1 S0 ; Set active low endstops
    ; Z probe configuration
    M307 H3 A-1 C-1 D-1
    M558 P9 F100 H5 T2000
    G31 X47 Y7 Z1.44 P25
    M557 X50:330 Y20:310 S40 ; Define mesh grid
    M569 P4 S0 ; Drive 4 goes backwards
    M350 X64 Y64 Z64 U64 E16:16 I1 ; Configure microstepping with interpolation
    M92 X320 Y320 Z1600 U1600 E92.6:92.6 ; Set steps per mm
    M566 X600 Y600 Z12 U12 E300 ; Set maximum instantaneous speed changes (mm/min)
    M203 X30000 Y30000 Z1200 U1200 E3600 ; Set maximum speeds (mm/min)
    M201 X2500 Y2500 Z500 U500 E2500 ; Set accelerations (mm/s^2)
    M906 X1000 Y1000 Z800 U800 E1000 I50 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S2 ; Set idle timeout
    M106 P2 S1 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M563 P0 D0 H1 ; Define tool 0
    ; Automatic power saving
    M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
  • Moderator
    How are you homing the Z axis? Does that work properly?
  • Yes the machine works, i can home all axis. Its only G29 and i tried G32 and that does the same. But i was of the understanding that G29 should be used for mapping.
  • Moderator
    Yes, but are you homing Z using a G30 probe move, or a G1 S1 Z move?
    G32 will run bed.g.
    Can you post your homing files and bed.g?
    I suspect it has something to do with your dual Z setup as well but I'm not sure.
    I see you're also running slightly behind on firmware releases. It may not matter, but just to be sure, try updating to the latest release. All you have to do is upload this single zip file. https://github.com/dc42/RepRapFirmware/releases/download/2.02/Duet2Firmware-2.02a.zip
  • Ok i will update it. Shit i think you are right. I can see that i have an M584 call in there... but if i delete this, then my second z-axe dos not work.... any idea?
    Your help is very appreciated ✌ ☺
    Here are my z-axis homing code:
    ; homez.g
    ; called to home the Z axis
    ; Lift Z relatively to current position
    G91
    G1 Z2 F6000 S2
    ; split Z motor control to Z and U
    ; for it to work we have to show U (param P4) in the UI
    M584 Z2 U3 P4
    ; Move Z and U down until the switches triggers
    G1 S1 Z-205 U-205 F1000 S2
    ; back to combined axes and hidden U
    M584 Z2:3 P3
    ; Back to absolute positioning
    G90
    ; Tell the firmware where we are
    G92 Z0
    ; lift Z after probing
    G91
    G1 Z3 F1000 S2
    G90
    ;--------------- repeat slowly----------
    M584 Z2 U3 P4
    G1 S1 Z-205 U-205 F50 S2
    M584 Z2:3 P3
    G90
    G92 Z0
    G91
    G1 Z10 F1000 S2
    G90
