    Wifi Errors: SPI timeout
    • garyd9
      garyd9 last edited by
      Duet Wifi h/w 1.04
      RRF 2.02 (release)
      Wifi Server 1.22
      DWC 1.22.6
      In the middle of a print, I was unable to connect to DWC. I was also unable to connect via telnet (which I have enabled.) According to my wifi AP, the duet was connected to the AP. In addition, I was able to successfully ping the duet from a PC. Finally, forcing my AP to disassociate from the duet (and letting the duet reconnect) didn't resolve the issue.
      On the paneldue "console" tab, I found lots of "Error retrieving WiFi status message: SPI timeout." This message was repeated 5 times every 5 seconds.
      I used an old macro to reset wifi via the paneldue (M552 S-1, G4 P500, M552 S1) and wifi came back up just fine with no issues/problems or messages. M122 run after the wifi was reset (via DWC) didn't show any problems (but I've included the text below for completeness.)
      For future use (in case I get this problem again), is there a set of commands I can put into a macro (that I can run from the paneldue) that will generate more useful information AND write it to a file on the duet's SD card? I have the feeling that M122 output would have been more useful before resetting wifi (but I doubt the paneldue would have displayed it.)
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.02 or later
      Board ID: 08DGM-9T6BU-FG3SN-6JKD6-3S46P-KUYVD
      Used output buffers: 3 of 20 (16 max)
      Static ram: 25524
      Dynamic ram: 98612 of which 0 recycled
      Exception stack ram used: 472
      Never used ram: 6464
      Tasks: NETWORK(ready,544) HEAT(blocked,1232) MAIN(running,600) IDLE(ready,200)
      Owned mutexes:
      Last reset 04:04:26 ago, cause: software
      Last software reset time unknown, reason: User, spinning module GCodes, available RAM 6660 bytes (slot 2)
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
      Error status: 0
      Free file entries: 9
      MCU temperature: min 43.8, current 45.3, max 46.3
      Supply voltage: min 23.4, current 24.2, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: ok, SG min/max 0/1023
      Driver 1: ok, SG min/max 0/414
      Driver 2: ok, SG min/max 0/286
      Driver 3: ok, SG min/max 0/1023
      Date/time: 2019-01-19 18:19:28
      Slowest loop: 99.40ms; fastest: 0.08ms
      I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
      Hiccups: 1185, StepErrors: 0, LaErrors: 0, FreeDm: 222, MinFreeDm: 120, MaxWait: 253197ms, Underruns: 0, 0
      Scheduled moves: 28388, completed moves: 28383
      Bed compensation in use: none
      Bed probe heights: -0.012 0.009 0.001 0.016 -0.007
      Heater 0 is on, I-accum = 0.5
      Heater 1 is on, I-accum = 0.6
      Segments left: 1
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is doing "G1 F2400 X-19.313 Y-8.565 E1.3258" in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 202.94ms; fastest: 0.00ms
      HTTP sessions: 1 of 8
      - WiFi -
      Network state is running
      WiFi firmware version 1.22
      WiFi MAC address xx:xx:xx:xx:xx:xx
      WiFi Vcc 3.41, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 27768
      WiFi IP address 192.168.7.10
      WiFi signal strength -56dBm, reconnections 0, sleep mode modem
      "I'm not saying that you are wrong - I'm just trying to fit it into my real world simulated experience."
        I don't recall anyone reporting that message before, neither have I seen it myself. My guess is that the WiFi module locked up.
        If it happens again, then the most useful thing you could do to help me diagnose it would be to connect a PC via USB, send M111 S1 P14 from it, and see if you get any WiFi debug messages. The M122 output might also be useful.
