How does this Axes configuration look.
Below is my axis configuration info. Duet wifi & Duex5 . Please check and see if anything is off.
M350 X16 Y16 Z16 U16 E16:16 I1 ; Configure microstepping with interpolation
M92 X160 Y160 Z1600 U160 E512.96:512.96 ; Set steps per mm
M566 X900 Y900 Z12 U900 E120:120 ; Set maximum instantaneous speed changes (mm/min)
M203 X6000 Y6000 Z180 U6000 E1500:1500 ; Set maximum speeds (mm/min)
M201 X500 Y500 Z20 U600 E10000:10000 ; Set accelerations (mm/s^2)
M906 X950 Y1300 Z950 U950 E1200:1200 I30 ; Set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeoutX and U Axis
NEMA 17.
0.9° Step Angle.
400 Steps Per Revolution.
2.8V Rated Voltage.
1.68A Phase.
3.5kg/cm (48.6oz/in) Holding Torque.Y Axis
NEMA 17.
0.9° Step Angle.
2.8V Rated Voltage.
1.68A Phase.
4.4kg/cm (61oz/in) Holding Torque.Z Axis x2
NEMA 17.
1.8° Step Angle.
200 Steps per Revolution.
1.33A Phase
2.8V Rated Voltage.
3.2kg/cm (32oz/in) Holding Torque.E0 and E1 2x
Bondtech QR Universal Extruder
Recommended motor current setting: 1.2A
E-steps setting: 492.45 steps/mmThank you
You've got a different acceleration for U than X. Shouldn't they be the same for IDEX?
Yes X&U it should be the same, Good catch. I am trying to optimize the printer.
