    Thermostatic fan control
    1263
    • cdl1701yahoo.com
      cdl1701yahoo.com last edited by
      I am wanting to control an enclosure fan so that it comes on when the E1 thermistor reaches 26c. I have it set up on PWM FAN1.
      M107 P1 S1 I0 F500 H1:2 T26
      But instead it turns on when the hotend starts to heat up. What am I doing wrong in the code above?
      • demonio669
        demonio669 last edited by
        Please, try this:
        M106 P1 L255 S255 F500 H2 T26
          @cdl1701@yahoo.com:
          H1:2 means turn the fan on when either thermistor 1 or thermistor 2 is at or above 26C. You need just H2 as in the previous reply.
          • cdl1701yahoo.com
            Ahh I misunderstood what the H1 was then. I thought H1 enables thermostatic mode and H-1 disables. But it means turn it on or off for that particular thermistor. So H0, H1, and H2 are available for thermostatic mode?
            • iDevelo
              iDevelo last edited by
              @cdl1701@yahoo.com:
              Correct.
              H-1 = Disable
              H0 = Heater 0
              H1 = Heater 1
              H2 = Heater 2
              • cdl1701yahoo.com
                So the fan still will not turn on when the inside of the box reaches temp. Should all three thermistors be showing up in the heaters section?
                  The third thermistor reading will not show up unless you configure it to be used as another extruder heater, or as a chamber heater. So I suggest you configure heater 2 as a chamber heater (even though it isn't really) using M141. You will also need the usual M305 commands to set thermistor parameters for heater 2.
                  • cdl1701yahoo.com
                    Ahh that did the trick. Thanks!
