    Leadshine BLM57180 Not Achieving Max Speed
    • ajlappundefined
      ajlapp
      Now that I finally have my external brushless servos working....thanks everyone on the forum....I'm not achieving max motor speed.
      These motors are rated for 3000RPM and should be able to hit 4000RPM max. The motor has a 1000 line encoder and is driving a 10mm pitch ball screw.
      With quadrature decoding my steps/mm are 400.
      Max Speed = (3000RPM * 4000steps/rev) / 400 steps/mm = 30,000 mm/min = 500mm/s
      I have my axis set as such with M203 set to 30,000.
      When I run the actuator I on;y hit about 100-125mm/sec.
      Am I hitting a limit because of the slow timing needed for these external steppers?
      Config
      ; generated by RepRapFirmware Configuration Tool v2 on Wed Jan 16 2019 13:17:53 GMT-0500 (Eastern Standard Time)
      M550 P"AAM_Large_Volume_Printer" ; Set machine name
      M551 P"password: ; Set password
      M552 P10.0.0.55 S1 ; Enable network and set IP address
      M553 P255.255.255.0 ; Set netmask
      M554 P192.168.1.254 ; Set gateway
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M584 X5:6 ; map drive 5:6 to X axis
      M92 X400 ; set steps/mm for X axis (drive 5 & 6)
      M569 P5 S0 T8.5:8.5:50.0:67.0 ; set drive timings for drive 5 (first drive on breakout board)
      M569 P6 S0 T8.5:8.5:50.0:67.0 ; set drive timings for drive 6 (second drive on breakout board)
      M92 Y80.00 Z4000.00 E400.00 ; Set steps per mm
      M566 X30000.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
      M203 X30000.00 Y6000.00 Z180.00 E1200.00 ; Set maximum speeds (mm/min)
      M201 X30000.00 Y500.00 Z20.00 E250.00 ; Set accelerations (mm/s^2)
      M906 X2000.00 Y800.00 Z800.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X762 Y1000 Z1000 S0 ; Set axis maxima
      M574 X1 Y1 S0 ; Set active high endstops
      M558 P1 H5 F120 T6000 ; Set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
      M557 X15:0 Y15:195 S20 ; Define mesh grid
      M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
      M563 P0 D0 H1 ; Define tool 0
      M305 P0 X151 T"J"
        With 8.5us minimum step pulse width and step pulse interval, the absolute maximum step pulse rate possible is 1000000/(8.5+8.5) = 58.8kHz. Allowing for some processing time, say about 50kHz. At 400 steps/mm the maximum speed is therefore 50000/400 = 125mm/sec.
        So the answer to your question is yes. To get higher speeds, you will need to reconfigure the drivers to reduce the steps/mm.
        • ajlappundefined
          ajlapp
          Touche...Looks like I need a faster screw or faster external driver.
          • Vetiundefined
            Veti
            also you ignored the very big warning for M584 to unmap the old assignment
