    Resume after heater1 failure
    • jamesadotyundefined
      jamesadoty
      Hi all:
      I'm back with more questions.
      My Tronxy X5SA was printing last night and while I was asleep the job failed due to the hot end getting too cold. I plan to replace the hot end and rewire for 24 volts in the near future.
      At any rate the printer said it created a save state, how do I resume the print? Or is this something I should have set up ahead of time, which I've not done yet.
        See https://duet3d.dozuki.com/Wiki/Setting_up_to_resume_a_print_after_a_power_failure#main. You can ignore the bit about setting up the power fail parameters, what you need is a suitable resurrect-prologue file so that M916 can be used to resume the print (if it is still attached to the bed).
          jamesadoty
          Thanks.
          I'm trying it now.
