    Delta printer does not print the full height on the outer edges
    1618
    • TBS
      TBS last edited by TBS
      I have a question about configuring the Duet Ethernet for my mid-sized delta printer.
      The printer has in the middle a print height of exactly 102.4 cm.
      At the outer edge the delta has a height with about 99 cm.
      In the middle he can print up to the top with 102.4 cm.
      Unfortunately, the printer can only print up to 89.9 cm at the outer edge.
      Only a sketch:
      In the picture, the printer is at the maximum height according to the duet. You can see that the delta arm does not go all the way up. It lacks about 9 cm, which are not driven up.
      Attached my current configuration:
      config.g
      config-override.g
      homedelta.g
      How do I have to change my configuration that he goes up to the top at the outer edge?
      Thank you.
      • NOVAprint
        NOVAprint last edited by
        It seems strange that you have that problem, does this effect the level of your bed?
        • ayudtee
          ayudtee last edited by
          Your M665 command is using a value of H1026.4, but according to your drawing is really only 111.4 (102.4+9). My guess is that your smart effector autocalibration routine that you are relying upon to set your endstops might be a little less inaccurate if you used a value that was closer to what the actual value is. I'd change it to H116.4 (based upon your drawing and photo + 5mm) and re-check. Once your calibration is set simply transfer those settings it derived (for M665 and M666) to your config.g
          • fcwilt
            fcwilt last edited by
            I think that your setting for max height is too large.
            Consider the situation when all carriages are at the very top. The nozzle will be centered.
            To move the nozzle to the max radius one or two of the carriages have to drop and in doing so the nozzle will also drop.
            Whatever height the nozzle is at in that condition is going to be appx the max height for your hardware.
            But it's late, I'm tired and could be totally wrong.
            Printers: A FT-5 with the 713 upgrade bits. A custom MarkForged style. A small Utilmaker style and a CoreXY from kits. Various hotends. All with a variety of Duets (2 and 3) running 3.3.0
            • TBS
              TBS last edited by
              Thanks for your answers.
              @NOVAprint: The auto leveling works (plus minus 0.3mm). I can compensate this with the H parameter in the leveling routine.
              @ayudtee: The height is not 116mm. The print height is in the center 1024mm.
              @fcwilt: The print height in the center is 1024mm. You are right. If the nozzle move to the outer egde, the nozzle moves a little down to the buttom (so the arm hit not the end stop) . BUT the nozzle should only move about 40mm down (without triggering the end stop). But the nozzle move about 125mm down. There nozzle move 85mm (125mm - 40mm) to much down.
              This waste build volume.
              fcwilt 1 Reply Last reply Reply Quote 0
              • fcwilt
                fcwilt @TBS last edited by
                @tbs said in Delta printer does not print the full height on the outer edges:
                @fcwilt: . BUT the nozzle should only move about 40mm down.
                I don't understand. If the carriage on, say, the X tower is up as high as it goes and you move the other carriages down so the nozzle is at the max radius and is adjacent to the X tower the nozzle is going to be at the max height regardless of how much it has moved down.
                So what do you mean by "should only move about 40mm down".
                • TBS
                  TBS last edited by
                  @fcwilt: I will make a video later today in the evening.
                    I haven't yet worked out what might be causing that problem. Nobody else has reported it, and I don't see anything similar on my delta.
                    What happens when you home the printer? Your homedelta.g file homes the towers, then commands Z to move down by 5mm, then centres the effector. Do the carriages drop by 9cm during this process? If so, at what step?
                    Here's the code that limits the height, as at firmware version 2.02:
                    const float diagonalSquared = fsquare(coords[X_AXIS]) + fsquare(coords[Y_AXIS]);
                    if (applyM208Limits && coords[Z_AXIS] < reprap.GetPlatform().AxisMinimum(Z_AXIS))
                    	coords[Z_AXIS] = reprap.GetPlatform().AxisMinimum(Z_AXIS);
                    	limited = true;
                    else
                    	// Determine the maximum reachable height at this radius, in the worst case when the head is on a radius to a tower
                    	const float maxHeight = homedCarriageHeight - sqrtf(D2 - fsquare(radius - sqrtf(diagonalSquared)));
                    	if (coords[Z_AXIS] > maxHeight)
                    		coords[Z_AXIS] = maxHeight;
                    		limited = true;
                    Variable homedCarriageHeight is set to the height at which each carriage triggers the endstop switch, corrected by the M666 endstop adjustments. D2 is the square of the rod length.
                    As it happens, I've just replaced that block of code as part of extending the delta kinematics to support up to 6 towers all with different rod lengths. So I can provide a new binary for you to try. But I'd rather find out why the 2.02 firmware isn't working for you first.
                    • bot
                      bot last edited by
                      In the picture you post, is your effector centered while at its maximum height? Both in terms of XY position and real-world position relative to your towers.
                      *not actually a robot
                      • TBS
                        TBS last edited by
                        Here is the announced video:
                        https://vimeo.com/313250184
                        Process:
                        The nozzle is homed with a height of 1024.5mm.
                        The nozzle moves in horizontal direction with G1 Y-350.
                        Than the printer shows a height of about 899mm.
                        But it is from the hardware arms a height of 990mm possible.
                        This height is never reached.
                        You can see that the arm is about 91mm under the maximum height (end stop).
                        Note:
                        If I execute G1 X-400 there are about 30mm more possible with the arms.
                        If I execute G1 X400 there are about 30mm more possible with the arms.
                        If I execute G1 Y400 there are about 5mm more possible with the arms.
                        • TBS
                          TBS last edited by
                          @fcwilt: After reading the comment from dc42 I understood what you meant.
                          This is probably the internal code implementation.
                          @dc42: If you have the new implementation for the dynamic height calculation you can send them to me by e-mail to test it.
                          But you are right. The I2C error is much more important. I would like to start my 430 hours printjob 😉
                          • fcwilt
                            What arm does the video show?
                            • TBS
                              @fcwilt: The video shows the right arm on the front or the theoretical position is about X500 Y-500.
                              The left arm on the front is similar with 91mm.
                              • fcwilt
                                Did you run the autocal feature when the homing file was as you posted?
                                TBS 1 Reply Last reply Reply Quote 0
                                  I've watched the video.
                                  1. Can you confirm that when you home the printer, all 3 carriages go right up to the endstop switches, then drop about 5mm?
                                  2. When you commanded Y to -350, did all 3 carriages drop? The video only shows one of them.
                                  • TBS
                                    1. Yes, i can confirm that all three carriage trigger the end stops and move 5mm down.
                                    2. The video is recorded in the front position.
                                      The carriage in the front left moves about 91mm down.
                                      The carriage in the front right moves about 91mm down.
                                      The carriage in the background middle moves more than 300mm down. But I have not messured the exakt value for the background carriage, yet.
                                    • bot
                                      bot last edited by
                                      Immediately after homing a delta printer, you can't freely move in X/Y without some moves causing a carriage to crash UP into an endstop.
                                      This move shouldn't produce the behaviour, but perhaps the printer is moving down to a level that allows full X/Y movement without the carriage crashing up.
                                      EG, if you gave the command G0 Y350, immediately after homing, the carriage would crash. Has the firmware been updated to prevent "illegal" moves of delta kinematics? IE ones that would put the printer at a height where the XY plane is not fully and freely accessible?
                                      • Danal
                                        Danal last edited by
                                        This may or may not have anything to do with your problem:
                                        The dimensions given in the M665 in the config-override.g you posted seem odd.
                                        M665 L1021.500 R527.601 H1030.482 B400.0 X-0.139 Y-0.828 Z0.000
                                        Specifically, B (printable bed radius) of 400 with a R (Delta radius, measured horizontally, measured "joint center to joint center" of 527, this seems a bit off. The point at which a diagonal arm pivots on the carriage is 157mm beyond the edge of the bed? Normally this is a gap just large enough to run a belt...
                                        Also, this makes your R (Delta Radius) more than half of your diagonal rod length. This would imply that the rods are at less than a 45 angle when everything is centered. Yet we can see in the video this is not true.
                                        Again, may or may not be related to the problem...
                                        • Danal
                                          Danal last edited by Danal
                                          As an aside to this:
                                          If you have 1021mm arms, it should be easily possible to achieve a print radius of 445mm, Going all the way to 450 causes the rods to be below a 20 degree angle in their "worst case" position.
                                          • TBS
                                            TBS @fcwilt last edited by TBS
                                            @fcwilt said in Delta printer does not print the full height on the outer edges:
                                            I have run the autoleveling routine and it was the same result.
                                            @danal said in Delta printer does not print the full height on the outer edges:
                                            I have changed the R parameter to 450, but it is the same result.
                                            • fcwilt
                                              But did you run delta calibration with the homing file as you posted?
                                              That homing file has an error in it which can mess up the delta calibration procedure.
                                              • Danal
                                                Please post a few photos of your bed & towers, with a tape measure or ruler. I am specifically interested in the physical bed size, and the offsets edge of bed to belt, and edge of bed to tower.
                                                Like this:
                                                • TBS
                                                  Yes, the files that I have posted are the current leveling files. Where are the errors in the file?
                                                  • fcwilt
                                                    The last three lines where you move down and center. You don't want to do that part.
                                                    Just leave them up triggering the endstops - that is what the delta calibration procedure assumes for a starting position.
                                                    I had that same centering code and could not get my delta to print well. I finally noticed in the section of the duet help on delta calibration that I was not supposed to do that. I removed it and ran calibration and the printer then printed just fine.
                                                    I'm not saying this is directly related to the problem we have been discussing but it is something you should fix and then run calibration again.
                                                    • Danal
                                                      There really is 120MM+ gap belt to the edge of the bed. Maybe more like 140MM to the tower itself. So those M556 numbers are better than I thought.
                                                      As others have said, clean up the homing file, re-calibrate, and see...
