    Warning: Driver(s) 1 stalled at Z height.
    • gnafin
      gnafin last edited by
      12:51:35 AMWarning: Driver(s) 1 stalled at Z height 6.20. i got it for the Z0 and Z1.
      this is on a AM8. i get the warning every time the z moves.
      ; generated by RepRapFirmware Configuration Tool on Sun Nov 04 2018 13:11:53 GMT+0100 (West-Europa (standaardtijd))
      M550 PAM8 ; Set machine name
      M552 S1 ; Enable network
      M587 S"SSID" P"Password" ; Configure access point. You can delete this line once connected
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      ;M584 X0 Y1 Z2:3 E4 ; Assign drivers to motors
      M92 X100 Y100 Z400 E413 ; Set steps per mm
      M203 X18000 Y18000 Z300 E3600 ; Set maximum speeds (mm/min)
      M201 X3000 Y1500 Z100 E1000 ; Set accelerations (mm/s^2)
      M566 X1200 Y900 Z12 E1200 ; Set maximum instantaneous speed changes (mm/min) (jerk)
      M906 X950 Y950 Z950 E950 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      ;M572 D0 S0.2 ; Pressure advance set to 0.1 seconds
      M208 X-9 Y-11.0 Z0 S1 ; Set axis minima
      M208 X220 Y220 Z200 S0 ; Set axis maxima
      M574 X1 Y1 S3 ; Set endstops controlled by motor load detection
      M574 Z1 S0 ; Set Z endstop
      M558 P1 H5 F120 T6000 ; Set Z probe type to unmodulated and the dive height + speeds
      G31 P438 X0 Y0 Z1.583 ; Set Z probe trigger value, offset and trigger height
      M557 X25:175 Y25:175 S20 ; Define mesh grid
      M143 H1 S285 ; Set temperature limit for heater 1 to 280C
      M307 H1 A304.1 C232.8 D7.1 S1 B0 ; Set PID tuning values for heater 1
      M106 P0 S0 I0 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M563 P0 D0 H1 ; Define tool 0
      T0 ; Select first hotend
      ; Automatic power saving
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
        I don't see any M915 commands in your config.g so I presume you must have them in your homing files. You can change R1 to R0 in your M915 command if you don't want to receive those warnings.
