Duet 2 Ethernet stops mid print
My duet 2 is brand new, been only running it for a week. I keep having this problem where it will randomly stop mid print and the duet seems to reset (not in the same spot every time). The heaters turn off and the web interface says print completed 100% please help me
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet Ethernet 1.02 or later
Board ID: 08DGM-917NK-F2MS4-7J1D4-3SD6N-1GTSF
Used output buffers: 3 of 20 (13 max)
Static ram: 25524
Dynamic ram: 98132 of which 0 recycled
Exception stack ram used: 272
Never used ram: 7144
Tasks: NETWORK(ready,928) HEAT(blocked,1232) MAIN(running,3844) IDLE(ready,200)
Owned mutexes:
Last reset 00:00:48 ago, cause: power up
Last software reset time unknown, reason: User, spinning module GCodes, available RAM 6192 bytes (slot 1)
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
Error status: 0
Free file entries: 10
MCU temperature: min 42.6, current 42.8, max 43.1
Supply voltage: min 12.4, current 12.4, max 12.5, under voltage events: 0, over voltage events: 0, power good: yes
Cache data hit count 108928736
Slowest loop: 1.11ms; fastest: 0.08ms
I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
Scheduled moves: 0, completed moves: 0
Bed compensation in use: none
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 4.45ms; fastest: 0.02ms
HTTP sessions: 1 of 8
Interface state 5, link 100Mbps full duplex -
According to the reset data in the report, the last reset was caused by power up. So it's likely that either you had a power brownout, or your PSU cut out temporarily (perhaps because it decided it was overloaded), or your power wiring has a bad connection. Check tat the VIN terminal block screws are tight.
After seeing your post i decided to attach a voltmeter and watch it during one of the stalls. For some reason my atx supply had been dropping below 10volts temporarily. I bought a led power supply from amazon and it seems to have fixed the issue completely
Thanks, I'll mark this as solved.
You can use M122 after printing to see how low the VIN voltage dropped.
