    Duet3D controlling relay - Spindle
    CNC
    • Mikethk
      Mikethk last edited by
      Hi all
      I want the Duet3D to control a relay that will shut down my spindle on end project. If i could write a macro to start the spindle via a relay, then it would be even more cool.
      I only looking for a clue if this is possible. And maybe where to look.
      Best regards
      Mike Kristensen
      Catalin_RO 1 Reply Last reply Reply Quote 0
      • Danal
        Danal last edited by
        Easily possible.
        M453 that places Duet in "CNC Mode" allows specifications of which logical pins to use for controlling the spindle with standard M3/M4/M5. No macros needed.
        For logical to physical pin mappings, see documentation at M42
        For all this, start here:
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M42_Switch_I_O_pin
        • Catalin_RO
          Catalin_RO @Mikethk last edited by
          @mikethk Let's go a little back closer to basics... what kind of spindle do you have on your CNC?
          • Mikethk
            I got a 230v Dewalt spindle. So i guees i have to use some relays.
            • Catalin_RO
              @mikethk Indeed, a relay or SSR are your only choices for that!
