    Duet WiFi Access Point setup problems
    Firmware installation
    3.1k
    • AKLivingundefined
      AKLiving
      I'm able to setup the access point to work great but unfortunately I can't seem to get it to work unless I send M552 S2 command anywhere to 1-6 times after booting up. I created a macro which does make it easier but it would be nice to get it working without booting up, going into macro menu, hitting macro, checking connection, hitting macro again, checking connection, repeat....
      I've read through many other people having difficulty as well and I've tried so many combinations I can't remember them all. I just can't get past having to enter the M552 S2 command more than what is already in my config.g. I live where you can't get internet other than on my phone so I don't use a home WiFi network and have to set up the Duet WiFi as an access point (one of the main reasons I bought it).
      Machine: Tronxy corexy
      Controller: Duet WiFi
      Firmware: 2.02a
      Web control: 1.22.6
      WiFi server: 1.22
      Here is my configuration with password removed below but working fine so that isn't an issue.
      ; generated by RepRapFirmware Configuration Tool v2 on Wed Jan 23 2019 15:02:09 GMT-0900 (Alaska Standard Time)
      M667 S1 ; Select CoreXY mode
      M550 P"TronxyX5SA" ; Set machine name
      M552 S2 ; Enable as an access point
      M589 S"TronxyC5SA" P"nnnnnnnn" I192.186.2.100 ; Configure access point parameters. Set SSID, WiFi password, & IP address to use.
      M569 P0 S0 ; Drive 0 goes backwards
      M92 X80.00 Y80.00 Z400.00 E418.5 ; Set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z6000.00 E600.00 ; Set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00 ; Set accelerations (mm/s^2)
      M906 X1000.00 Y1000.00 Z1000.00 E100.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X40 Y40 Z0 S1 ; Set axis minima
      M208 X330 Y330 Z400 S0 ; Set axis maxima
      M574 X1 Y1 S0 ; Set active low and disabled endstops
      M574 Z1 Z2 S2 ; Set endstops controlled by probe
      M558 P5 I1 H5 F120 T6000 A10 R0.5 B0 ; Set Z probe type to modulated and the dive height + speeds
      G31 P500 X-30 Y-40 Z5.35 ; Set Z probe trigger value, offset and trigger height
      M556 S50 X0 Y0 Z0 ; Set orthogonal axis compensation parameters
      M557 X55:330 Y65:330 S15 ; Define mesh grid
      M305 P1 B4725 C7.060000e-8 ; Set thermistor + ADC parameters for heater 1
      M143 H1 S300 ; Set temperature limit for heater 1 to 300C
      M563 P0 D0 H1 ; Define tool 0
      ; Automatic power saving
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
        Remove the M589 command from your config.g file and try again. It only needed to be sent once, the parameters are stored in the WiFi module.
        • AKLivingundefined
          AKLiving
          I tried removing M589 with no change. I tried M588 and then re-tried setting up the network again. I also tried M552 S0 followed by M552 S2, which I believe I saw in some other earlier firmware version posts with people trying to get access point mode working.
          The Duet 2 WiFi still needs M552 S2 command entered after boot up in order to run and more often than not it needs the command sent several times. The Paneldue is great to have so that the macro is easy to use without having to physically connect through USB and use YAT to send the command.
          Duet WiFi running as an access point works great without any problems, dropped signal, or errors once I can actually connect.
            Try connecting a PC or laptop to the Duet via USB, running YAT or Pronterface. Send M111 S1 P14 to enable WiFi debugging. Then try sending the M552 S2 command (from USB or PanelDue, it doesn't matter). If it fails to start up as an access point, let us know what debug messages if any it sends to the PC.
            AKLivingundefined 1 Reply Last reply Reply Quote 0
            • aidarundefined
              aidar
              If it isnt typo, then change your IP address. 192.186.2.100 is known static IP of some server and shouldnt be used by anyone else. You probably want to use 192.168.2.100
              • AKLivingundefined
                AKLiving @aidar
                @aidar said in Duet WiFi Access Point setup problems:
                I changed it to 192.168.2.100. This did not change the problem I'm having.
                • AKLivingundefined
                  AKLiving @dc42
                  @dc42 said in Duet WiFi Access Point setup problems:
                  Here are my current network settings after the changes recommended:
                  And the report from YAT when enabling WiFi debugging. I'm not sure what the M596 warning is about. I don't have that command in my config.g
                  RepRapFirmware for Duet 2 WiFi/Ethernet Version 2.02(RTOS) dated 2018-12-24b1<LF><LF>Executing config.g...Warning: M596 command is not supported<LF>Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 606C.<LF><LF>Done!<LF>RepRapFirmware for Duet 2 WiFi/Ethernet is up and running.
                  m511 s1 p14
                  M511 command is not supported<LF>ok<LF>
                  M111 S1 P14
                  Debugging enabled for modules: WiFi(14)<LF>Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) Display(15)<LF>ok<LF>
                  M552 S2
                  ok<LF>WiFi reported error: Failed to start access point<LF>WiFi module is idle<LF>
                  M552 S2
                  M552 S2
                  M552 S2
                  M552 S2
                  M552 S2
                  ok<LF>WiFi module is providing access point TronxyX5SA, IP address 192.168.2.100<LF>
                    OK, leave it with me - I'm having problems starting AP mode too.
                    • AKLivingundefined
                      AKLiving @dc42
                      @dc42 Thank you. Just let me know if you need me to try anything else. The Duet WiFi is so much superior and configurable to what I had I'll live with my current process of hitting my macro a few times for now. With the awesome Paneldue at least I don't have to connect USB to send commands.
                        @AKLiving, please try installing DuetWiFiServer.bin version 1.23beta1 from https://www.dropbox.com/s/gkb6rulcayiqjcm/DuetWiFiServer.bin?dl=0 and let me know whether it fixes the problem.
                        If you need to use YAT to get debug info, go to Settings->Text settings and set the line ending to <LF>. That will result in better formatting of the debug info.
                        • AKLivingundefined
                          AKLiving @dc42
                          After 2 reboots it is now working. It allows me to have 2 devices connected at the same time too! (iPhone and laptop with win10) I’ll cycle it a few more times on Monday and let you know how it’s going.
                            Thanks, I'll wait to hear from you again.
                            • AKLivingundefined
                              AKLiving @dc42
                              @dc42 It has been working without a single failure to connect. Thank you very much.
                                Thanks for the feedback. I included this version of DuetWiFiServer with the RRF 2.03beta1 release. So anyone else having the same problem can pick it up from the 2.03beta1 release area.
                                supermarioprofundefined 1 Reply Last reply Reply Quote 0
                                • supermarioprofundefined
                                  supermarioprof @dc42
                                  I'm having similar problems with AP mode:
                                  on every reboot
                                  I need to open Pronterface,
                                  force M552 S0,
                                  force M552 S2 a few times (normally 3),
                                  than AP mode goes on and everything works.
                                  I'm on latest stable, 2.02.
                                  I also tried to add
                                  M552 S0
                                  G4 S5
                                  M552 S2
                                  in config.g, thinking it may be a question of time to wake up for AP mode. No joy.
                                  So:
                                  • should I update to 2.03beta1 or 2.03beta2?
                                  • should I update DuetWifiServer.bin only, or Duet2CombinedFirmware.bin too?
                                  My config.g and SETNETWORK macro attached
                                  thanks!
                                  0_1551155432746_config.g
                                  0_1551155466497_SETNETWORK.txt
                                    If you want to stay on firmware 2.02 then you can just upgrade DuetWiFiServer to version 1.23beta.
                                      @dc42 thanks!
                                      I installed DuetWifiServer.bin AND Duet2CombinedFirmware.bin, 2.03beta1 (I installed before reading your answer!),
                                      kept
                                      M552 S0
                                      G4 S5
                                      M552 S2
                                      and now access point mode works good!
