    extremely small speed value (F) crashing Maestro
    • gnydickundefined
      gnydick
      My slicer generated this speed setting, and boy was the printer not happy. It basically just locked up.
      G1 F2.60524e-310
        There is a known issue in the current firmware that if you use scientific format in a parameter, the exponent part gets mistaken for an E parameter as well. So the Duet is trying to retract 310mm of filament very slowly, giving the appearance of having locked up. This is already fixed in the 2.03 firmware builds that I am working on.
        gnydickundefined 2 Replies Last reply Reply Quote 0
        • gnydickundefined
          gnydick @dc42
          @dc42 ahhh. btw, there's no category for reporting bugs/issues, would be helpful rather than trying to figure out where to post something.
          • gnydickundefined
            gnydick @dc42
            This post is deleted!
            • DocTruckerundefined
              DocTrucker
              Not sure what happens if you request a feed rate below 0.5mm/sec but you would have also hit on the minimum feedrate:
              https://duet3d.dozuki.com/Wiki/Gcode#Section_G0_G1_Move
