    M569 for choosing stealth chop is not working
    1.4k
    • Skimmyundefined
      Skimmy
      If I do send
      M569 P0 S0 D3
      via console, I get the error message:
      Error: M569: Driver 0 does not support mode 'stealthChop'
      But the docs clearly say that the DUET uses TMC2660 and lists TMC2660 as stealth chop capable. Am I missing something?
      Im running the latest firmwares with a DUET + DUEX5:
      Firmwarename: RepRapFirmware for Duet 2 WiFi/Ethernet
      Firmware Elektronik: Duet WiFi 1.02 or later + DueX5
      WiFi Server Version: 1.22
      Web Interface Version: 1.22.6
      my blog: https://www.well-engineered.net
      • nhofundefined
        nhof
        Stealth chop is for the TMC2224 drivers on the Duet Maestro.
        The TMC2660 drivers on the Duet 2 do not have stealth chop capability.
        • Skimmyundefined
          Skimmy
          ah, thx for clarifying. Then, the docu is a bit misleading 😕
          https://duet3d.dozuki.com/Wiki/Gcode#Section_M569_Set_motor_driver_direction_enable_polarity_and_step_pulse_timing
          Dnn (firmware 2.0 and later, only applies to TMC2660 and TMC22xx stepper drivers) Driver mode: 0=constant off time, 1=random off time, 2=spread cycle, 3=stealthChop or stealthChop2. The default is spreadCycle for TMC2660 drivers and stealthChop2 for TMC22xx. In stealthChop mode the drivers will switch over to spreadCycle automatically at high speeds, see the V parameter.
          • nhofundefined
            nhof
            I updated the docs to clarify that mode 3 only applies to the TMC22xx drivers.
            seraserundefined 1 Reply Last reply Reply Quote 1
            • seraserundefined
              seraser @nhof
              @nhof OK, 22xx is not 2208 with external adapte, so I think no support for 2208
              Thank you
                dc42 administrators @seraser
                @seraser said in M569 for choosing stealth chop is not working:
                Thank you
                Duet Maestro supports two external TMC2208 or TMC2224 drivers. Duet WiFi and Ethernet only support TMC2660 and dumb step/direction/enable drivers.
                • seraserundefined
                  seraser
                  Ok, thank you, but is strange, to much over extrusion with defaults settings.
                    Are the microstepping jumpers set correctly for x16 ? Have you set the correct steps/mm ?
                    • seraserundefined
                      seraser
                      Ohh, you are right, maybe my jumpers, three inserted and I now think only two are needed for TMC2208, I will check.
                      Thank you.
