external driver "iHSS60" connection-question
The M569 T parameters default to zero, so they will be zero for the internal drivers assuming you don't change them.
Thanks!
Also thanks for your advise with the maximum obtainable speed related to the microsteppingamount -> Will shoot for something around 200-300 steps per mm then
Edit: Faster(more/higher) possible micro-stepping for external drives could be a cool feature for the new board you are cooking up, just sayin -
@lb said in external driver "iHSS60" connection-question:
That's likely to be impossible. The step pulse length and step pulse interval needed by the external drivers limit the maximum step pulse frequency. Whereas for the internal drivers, we expect to see an increase in the maximum step pulse rate.
Ah - learned something. Thanks!
