    stealthchop: "motor phase B may be disco..."
    1.2k
    • gnydickundefined
      gnydick
      Seems like no matter how slow or gently I print, I always get these messages when using stealthchop
      maestro - 2.02
        1. Please check that you are using the 2.02 release firmware, not a 2.02RC version.
        2. What motor current have you set?
        3. Which motor or motors does the message mention?
        4. Is it only phase B that is mentioned, or is phase A sometimes mentioned too?
        5. What VIN voltage are you using?
        6. A link to the motor data sheet may also be helpful.
        gnydickundefined 1 Reply Last reply Reply Quote 0
        • gnydickundefined
          gnydick @dc42
          @dc42 2.02(RTOS) (2018-12-24b1), it will happen on any motor, but most often on Z, and either or both phases, VIN fluctuates between 24 and 25 even though I have a good meanwell 600W psu with feedback sensor.
          M906 X1400 Y1400 Z900 E1500:1400 I70; Set motor currents (mA) and idle current percentage
          XY: https://www.moonsindustries.com/p/nema-17-high-precision-hybrid-stepper-motors/ms17ha2p4200-000004611110015919
          2xZ: whatever crap came with the promega, I converted it
          E: https://e3d-online.dozuki.com/Document/120/.pdf
            Thanks. Please run M569 P0 to list the driver settings, then M569 P1 etc. up to P5. List the results here.
            • gnydickundefined
              gnydick @dc42
              10:09:19 AMM569 P0
              Drive 0 runs in reverse, active low enable, step timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, tpwmthrs 1 (4791.1 mm/sec)
              10:09:18 AMM569 P1
              Drive 1 runs in reverse, active low enable, step timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, tpwmthrs 1 (4791.1 mm/sec)
              10:09:16 AMM569 P2
              Drive 2 runs forwards, active low enable, step timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, tpwmthrs 1 (1890.3 mm/sec)
              10:09:15 AMM569 P3
              Drive 3 runs in reverse, active low enable, step timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, tpwmthrs 1 (4039.1 mm/sec)
              10:09:14 AMM569 P4
              Drive 4 runs forwards, active low enable, step timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, tpwmthrs 1 (4039.1 mm/sec)
                Thanks. You have tpwmthrs in your M569 commands set much too low on all drives. StealthChop is problematic at high speeds.
                • gnydickundefined
                  gnydick @dc42
                  My initial post said, no matter how slowly or gently I print. I'm not trying to print at high speed when this happens.
                    My guess is that stealthChop is using a very low motor current. Perhaps it hasn't calibrated itself to your motors very well. It normally does that calibration during the initial homing moves. It might work better if you change the speed of your homing moves.
                    You could also try adding this at the start of homeall.g:
                    G91
                    G1 S2 X0.02 Y0.02 Z0.02
                    G4 P100
                    G90
                    This moves all the motors a tiny amount, then pauses to give the drivers time to measure the standstill characteristics of the motors, before proceeding with homing.
                    gnydickundefined 2 Replies Last reply Reply Quote 1
                    • gnydickundefined
                      gnydick @dc42
                      @dc42 I've already been doing that. I don't home as part of my print process, I home manually.
                        What do you mean by "I home manually"? If you mean that you press the Home button in DWC or send G28, that's fine. If you mean you push the axes to the right positions by hand, or do short jogging moves, that isn't, because stealthChop needs a long medium speed move to calibrate the motor.
                        • gnydickundefined
                          gnydick @dc42
                          @dc42 I click the home button. OK, I'll look at my init code to see if it meets your suggested.
                          • gnydickundefined
                            gnydick @dc42
                            @dc42 btw, I'm assuming I need an M564 H0 otherwise it won't move?
                            G91
                            G4 P100
                            G90
                              G1 S2 moves will work without M564 H0.
