    Maestro and 12864 startup
    • DaveAundefined
      DaveA
      Hope I'm not being a pest today. I decided to take a break from crimping pins and decided to move my RepRapDiscount 12864 lcd from the ramps over to the Maestro. I loaded the menu files from github into the menu directory, plugged in the two ribbon cables and fired it up. I only get the lcd backlight showing. The Maestro is alive as I can see it from the DWC. Is their a config change to enable the lcd or am I missing something?
      • aidarundefined
        aidar
        You need probably this : https://duet3d.dozuki.com/Wiki/Gcode#Section_M918_Configure_direct_connect_display
        • DaveAundefined
          DaveA
          Thanks, that did it. I guess I need to read every bit of the gcode command list. It's not mentioned in https://duet3d.dozuki.com/Wiki/Duet_2_Maestro_12864_display_menu_system
          Off to new stuff.
            dc42 administrators @DaveA
            @davea said in Maestro and 12864 startup:
            It is now! Thanks for pointing this out.
