    Multiple servo motors on one duet board
    • Arnixundefined
      Arnix
      Hi.
      Can i hook up 6 servo SD motors to duet ?
      A.
        If you mean step-direction servos to take the place of stepper drivers, then you can connect up to 7 to a Duet WiFi or Duet Ethernet. 5 can be connected to the expansion bus, using the expansion breakout board if you need to shift the signals levels to 5V and higher current. 2 can be connected to the CONN_SD connector, but you will probably need to connect them via level shifters to increase the signal level to 5V and also increase the available current.
