    M24 in macro not resuming print
    • Dominikundefined
      Dominik
      Hi, I'm setting up filament change during print with M600 code. This is my filament-change.g :
      ;Change filament during print
      M83               ; relative extruder moves
      G1 E-10 F2000     ; retract 10mm of filament
      G91               ; relative positioning
      G1 Z5 F360        ; lift Z by 5mm
      G90            	  ; absolute positioning
      G1 X10 Y10 F3000  ; go to X=10 Y=10
      G1 E-150 F1500 	  ; Retract 150mm of filament at 1500 mm/min
      M400 		  ; Wait for the moves to finish
      M300 S2000 P100   ; Beep
      G4 P200
      M300 S2000 P100
      G4 P200
      M300 S2000 P100
      G4 P200
      M300 S2000 P100
      G4 P200
      M300 S2000 P100
      M291 P"Insert new filament" R"Filament change" S2
      G1 E40 F100 	; Feed 40mm of filament at 100mm/min
      M291 P"Press OK to resume" R"Filament change" S2
      G1 E-10 F3600   ; retract 10mm of filament
      M24		; Resume print
      The problem is that M24 wont resume print. However, if I enter M24 in web console, or hit resume on LCD it resumes. I'm running version 2.02(RTOS) (2018-12-24b1) on Maestro.
      Am I doing something wrong here ? Thanks.
        I've put this on my list to investigate. What I think is happening is that the status gets set to 'pausing' while filament-change.g is running, and 'paused' when it finishes. In which case, we'll need to handle M24 when executed within filament-change.g or pause.g specially.
