    Strange issue when manually restarting jobs
    • MortarArt
      MortarArt last edited by
      I've run into this issue twice now, and I'd like to understand what I'm doing wrong. After an error in a print, I've killed the job, rehomed and cut the gcode file, to the layer it was last on, re-uploaded it and started it again, at 20% speed (controlled in DWC).
      While I've done this a variety of times, only twice, I've had an issue where the restarted print massively over-extrudes. Probably by a factor of about 10, obviously causing the resume to fail.
      This is the start gcode of the last file I attempted to resume. Shouldn't setting G92 E0 avoid this?
      ; New layer
      G10
      G92 E0
      G1 Z3.650 F15000.000
      G1 X171.814 Y41.685 F15000.000
      G11
      G92 E0
      G1 F7200
      G1 X171.822 Y48.563 E0.32655
      G1 X175.107 Y49.680 E0.49125
      G1 X178.831 Y51.061 E0.67981
        Are you slicing with relative or absolute extrusion?
        • MortarArt
          I'm actually not sure. I'm using slic3r 1.3.1-dev
          I checked the settings and found:
          "Relative E distances" is not checked.
          "Volumetric E" is not checked.
            Looks like you have sliced using absolute extrusion, but you have the default set as relative extrusion in config.g. Your GCode file will have a M82 command at the start to select absolute extrusion, but that command is missing when you cut that bit out of the file.
            • MortarArt
              So I thought I'd solved this issue, because I restarted a few jobs, after finding an M83 command in the resume.g file, which I've subsequently commented out.
              But it's back. And I've tried a few things now to see if I can get around it. Pause job, M82, resume job. Cancel job, M82, resume job.
              Mind you this is on my old Duet 0.6, using FW 1.18.1
              I'll update further if I figure out what's happening.
