Unsupported Command Error
  • Hi
    Im trying to configure my delta printer for sensorles homing but when ı click Home button on web ı getting this error
    G28
    Error: unsupported command: M915 X Y Z S2 F1 R0
    M80					;PSU ON
    ; Homing file for RepRapFirmware on Large Kossel
    ; Sensorless Homing test file for RepRapFirmware on Kossel
    M915 X Y Z S2 F1 R0    ;set stall detect drives, S-threshold (-64 to 63), F1 filtered, R-log only
    M400					; make sure everything has stopped before we make changes
    M574 X2 Y2 Z2 S3			; set endstops to use motor stall
    M913 X30 Y30 Z30			; reduce motor current to 50% to prevent belts slipping
    G91					; use relative positioning
    G1 S1 X700 Y700 Z700 F2000		; move all carriages up 700mm, stopping at the endstops
    G1 Z-5 F2000				; down a few mm so that we can centre the head
    G90					; back to absolute positioning
    M400					; make sure everything has stopped before we reset the motor currents
    M913 X100 Y100 Z100			; motor currents back to normal
    G1 X0 Y0 F2000				; centre the head and set a reasonable feed rate
    ;M574 X2 Y2 Z2 S1			; set endstops back to normal so that homedelta.g works
    I found that on here (https://forum.duet3d.com/topic/4568/sensorless-homing-for-deltas/5)
    and copied it
  • @mekala
    What firmware version are you using?
    Possibly M915 is not allowed with G28. The example test macro look like this:
    ;''' Sensorless Homing test file for RepRapFirmware on Kossel'''
    M913 X50 Y50 Z50 ; reduce motor current to 50% to prevent belts slipping
    G1 S1 X700 Y700 Z700 F4000 ; move all carriages up 700mm, stopping at the endstops
    Which Duet are you using? The stepper drivers on the Maestro do not support stall detection. The ones on the Duet WiFi/Ethernet do.
  • Im using Duet wifi
    @fcwilt
    It's worked thanks
