    Messages not automatically closing [Solved]
    Duet Web Control
    • ephemerisundefined
      ephemeris
      ephemeris 2 Feb 2019, 15:12
      Every regular message (like Layer 2, z=0.4) stays on screen indefinitely . I come back and they pile up from the bottom to the top of my browser window and I have to each one separately. How do I make them auto close?
      'Do not close error messages automatically' is NOT on.
      Firefox 64.0.2
      Duet Web Control 2.0.0-RC3
      Electronics: Duet WiFi 1.0 or 1.01
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.02(RTOS)(2018-12-24b1)
      Duet WiFi Server Version: 1.22
        Can you post the gcode giving these messages?
          ephemeris
          M117 Layer 2, Z=0.800
            Phaedrux Moderator @ephemeris
            Ok, now the question is, why is the slicer adding them? Was that something you setup? If so, is it possible to change from M117 to M291 and set a timeout?
            https://duet3d.dozuki.com/Wiki/GCode#Section_M291_Display_message_and_optionally_wait_for_response
              Your probably have a M117 command in the layer change script of your slicer. I suggest you remove it.
                ephemeris
                I actually liked the layer change message. It was done with a Simplify3d post processing replace command. Unfortunately, their syntax is pretty limited so there's no way I can see to do it with M291 because of the double-quote characters on the P argument.
                Thanks for the prompt responses.
