    External Drivers for Nema 34 Steppers
    external driver nema34 duet wifi
    • Darnz
      Darnz last edited by
      alt stepper motor
      alt Stepper driver
      Hoping someone may assist me.
      I am building a large scale Cartesian Printer(2000mm/2000mm/2000mm).
      Ball skrews being used for all axes-20mm.
      Same Nema 34’s and DQ860MA External drivers being used for X(1 of), Y(2 of), and Z(4 of).
      The Duet WiFi will be on a 24V PSU
      The external drivers are being supplied from a 48Volt PSU.
      The decision was only recently made to make use of a Duet WiFi board, but I failed to research enough as I see now that external drivers require 5V and the Duet provides 3v.
      My concerns at this point are as follows:
      (1) Will the 3v signal from the board be sufficient to run the external drivers? Keep in mind that Z axis for example has 4 drivers that will need to be controlled from the Duet.
      (2)If so, how are they connected ?
      (3) Can the connections be made directly to the expansion plug on the Duet WiFi.
        Some external drivers are happy with 3.3V signals. You select a set of STEP, DIR and EN pins from the expansion connector or form CONN_SD. Connect driver PUL+ to STEP, DIR+ to DIR, EN+ to EN. Connect PUL-, DIR- and EN- to ground. In your M569 command for that driver, use R1 to invert the direction of the EN signal.
        Alternatively you can buy this https://www.duet3d.com/DuetAddons/Expansion_Breakout to boost the step/dir/en signals and make it easier to connect 5 drivers. You don't need to invert the EN signal, that's done on the breakout board. For your remaining 2 drivers you can connect 5V level shifters/buffers to the outputs on the CONN_LCD connector. One 74HCT365 or 74HCT367 chip could be used to convert all 6 signals (two sets of step/dir/en).
        • Darnz
          Thank you for your response.
          Could I make use of expansion plug pins for my XY and Z?
          So useE2 for my X
          Use E3 for my Y
          And use E4 for my Z.
          Do you think I may have a problem with one pin feeding signal to upto4 drivers?
            dc42 administrators @Darnz last edited by
            @darnz said in External Drivers for Nema 34 Steppers:
            So useE2 for my X
            Use E3 for my Y
            Yes, use the M584 command in config.g to specify which drivers your axis motors use.
            You might be able to drive 4 drivers from one expansion breakout board output. Or you could use E4 and E5 to drive 2 Z drivers each.
