Cannot add network SSID to remembered list
As the title suggests, I've been stuck on the first step of using the duet 2 WiFi board. I'm using YAT and I've been trying to add my home network using the M587 S"your-network-ssid" P"your-network-password" (with my SSID and password replaced appropriately) command and I get a return that says the board failed to add the SSID to the remembered list. This was out of the box, I have since looked through the forum to find similar problems and this is what I've tried so far:
-Updating the firmware (to the same version of 2.02) following Fallback Procedure #1 --- still fails to add SSID
-Updating the firmware to the new 2.03 beta1 that came out yesterday --- still fails to add SSIDI've now reverted to 2.02 and it still doesn't work so I ran the M122 command and here is the returned diagnostic:
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.02 or later
Board ID: 08DGM-917DA-G4MSJ-6J9D6-3S46J-1TPRB
Used output buffers: 1 of 20 (1 max)
Static ram: 25524
Dynamic ram: 98840 of which 0 recycled
Exception stack ram used: 272
Never used ram: 6436
Tasks: NETWORK(ready,544) HEAT(blocked,1232) MAIN(running,3860) IDLE(ready,200)
Owned mutexes:
Last reset 00:02:21 ago, cause: software
Last software reset time unknown, reason: User, spinning module GCodes, available RAM 6380 bytes (slot 0)
Error status: 0
Free file entries: 10
MCU temperature: min 26.8, current 29.0, max 29.1
Supply voltage: min 0.0, current 0.3, max 0.3, under voltage events: 0, over voltage events: 0, power good: no
Driver 0: ok, SG min/max not available
Driver 1: ok, SG min/max not available
Driver 2: ok, SG min/max not available
Driver 3: ok, SG min/max not available
Driver 4: ok, SG min/max not available
Cache data hit count 311458241
Slowest loop: 4.18ms; fastest: 0.06ms
I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
Scheduled moves: 0, completed moves: 0
Bed compensation in use: none
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is ready with "M122" in state(s) 0
aux is assembling a command in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 1329.94ms; fastest: 0.00ms
HTTP sessions: 0 of 8- WiFi -
Network state is changing mode
WiFi module is idle
WiFi firmware version 1.22
WiFi MAC address bc:dd:c2:89:9f:e0
WiFi Vcc 3.40, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 31856
ok
Error retrieving WiFi status message: SPI timeout
WiFi module is idle
WiFi module is idle
Failed to change WiFi mode (code -7)
I now see there are some errors at the end there but need help on what to do now. Could it be a firmware issue or a board/WiFi module problem?
Thanks in advance,
Ed
- WiFi -
Rather than sending the commands through YAT, you can try taking the SD card out of the duet, putting it in your PC and editing config.g to include you SSID adding command and then powering up the Duet. It it works you can then just remove the SSID command from config.g so it doesn't get run every time.
My Duet Wifi 1.04 would always forget about a third SSID network that I had set up, until I removed the test one that it ships with. I suspect that there isn't a lot of memory in the wifi module for networks. Remove any networks that are currently stored in there, and try again.
Try re-installing the DuetWiFiServer firmware. Aside from the 1.22 version shipped with RRF 2.02, the 1.23beta1 version supplied with RRF 2.03beta1 is compatible 2.0, 2.01 and 2.02 versions of RRF
Try sending M552 S0 before you run M587. If it still doesn't work, try M552 S-1 followed by M552 S0.
Thanks to everyone for replying so quickly, and big thanks to dc42!
I installed the DuetWiFiServer firmware from the 2.03 beta1 as you suggested and then ran M552 S0 before M587 and it worked like a charmGot my IP now so time to set it all up!
Thanks again to everyone, no more issues here.
