    MPCNC: 12V or 24V?
    Off Topic
    1.5k
    • wilrikerundefined
      wilriker
      I am thinking about (or rather try to not think about 😂 ) building a MPCNC. Since it does not have any heater components (with high currents) and probably won't move very fast (at least not while cutting) I think 12V would be sufficient assuming the spindle will be powered separately.
      Is there anything I am missing that would be improved by using 24V?
      Manuel
      My Tool Collection
      • Vetiundefined
        Veti
        you want 24v for the nema motors.
        You will get more torque out of them.
        • wilrikerundefined
          wilriker @Veti
          @veti Why would 24V result in more torque when the motor drivers are current based? 😕
          Manuel
          My Tool Collection
          dragonnundefined 1 Reply Last reply Reply Quote 0
          • dragonnundefined
            dragonn @wilriker
            @wilriker At high speeds. Read about BackEMF.
            When the motor BackEMF exceeded the power supply voltage stepper motors are losing torque.
            And a stepper driver can not push more then the power supply voltage.
            That is why stepper motors in CNC a driven often with 40-50V
            • wilrikerundefined
              wilriker @dragonn
              @dragonn I know about the high speed part. But for a MPCNC high speeds are only for travel and I could live having them at say 100mm/s max. I don't think I will be cutting with 100mm/s. Except maybe paper. 😂
              Manuel
              My Tool Collection
              • dragonnundefined
                dragonn
                100mm/s doesn't really tell much because what matters is the rotating speed of the motor.
                https://reprapfirmware.org/ here is a nice EMF calculator, just do you math for 12V and 24V
                • deckingmanundefined
                  deckingman @wilriker
                  @wilriker
                  Manuel,
                  Turn your question on it's head. Then it becomes "why would a 12v PSU be better than a 24V one"? Generally, they seem to cost the same. The answer may be a factor of what other peripherals do you want to power ( fans, lights etc) and are these peripherals available one voltage but not another?
                  • wilrikerundefined
                    wilriker @dragonn
                    @dragonn I know the EMF calculator. It was probably the most visited webpage in my browser's history for quite a while while I was selecting new motors for my printer. 😁
                    @deckingman I think your idea is the better approach here. Also currently this is all in the just-wanna-have-it stage. I have absolutely no need for a MPCNC I would just build it to have it built.
                    And you are right, peripherals are (in my experience) more widely available for 12V than for 24V.
                    I am going to mark this question as solved with: 24V is always better for your steppers because they could run faster than with 12V. And a buck-down converter can always take 24V to 12V in case of peripherals not available at native 24V.
                    Manuel
                    My Tool Collection
