Height Map - File Not Found
If I call up the height map in the web interface it opens as expected but if I then press the refresh button the map clears and I get the message "File not Found" If I restart the web interface it will load again OK . I have checked in the system files and it shows the up to date CSV file as does the SD card when looked at via a card reader on the PC .
Not a big issue but annoying, any help to resolve it appreciated. -
Thanks for the report. Which version of Duet Web Control are you using?
Duet Web Control 2.0.0-RC3
Electronics: Duet WiFi 1.02 or later
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.02(RTOS) (2018-12-24b1)
Duet WiFi Server Version: 1.22I knew you would ask for that! Sorry for omitting it.
It work as expected for me
Doug
it is the same for me i need to reload than is good
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.03beta1 (2019-02-03b3)
Duet WiFi Server Version: 1.22 -
Me too, I need to refresh the page as I get the "File not found" message if I press the refresh button.
info
About
Duet Web Control 2.0.0-RC3Electronics: Duet Maestro 1.0
Firmware: RepRapFirmware for Duet 2 Maestro 2.03beta1 (2019-02-03b3)
