    LaErrors, should I care about them? S3D
    • dragonnundefined
      dragonn
      I noticed I am getting some LaErrors on 2.02 firmware. Is this due I am using Simplify3D? I know it doesn't produce good quality g-code (as I remember the segment length isn't even).
        M122
        RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.02 or later
        Board ID: 08DGM-9568A-F23SD-6JTDG-3SD6P-1UN7D
        Used output buffers: 3 of 20 (16 max)
        Static ram: 25524
        Dynamic ram: 98624 of which 0 recycled
        Exception stack ram used: 512
        Never used ram: 6412
        Tasks: NETWORK(ready,544) HEAT(blocked,1176) MAIN(running,3868) IDLE(ready,200)
        Owned mutexes:
        Last reset 11:55:08 ago, cause: software
        Last software reset at 2019-02-08 22:23, reason: User, spinning module GCodes, available RAM 6324 bytes (slot 2)
        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
        Error status: 0
        Free file entries: 10
        SD card longest block write time: 134.4ms, max retries 0
        MCU temperature: min 28.4, current 32.2, max 34.6
        Supply voltage: min 0.3, current 0.6, max 27.7, under voltage events: 1, over voltage events: 0, power good: no
        Driver 0: standstill, SG min/max 0/1023
        Driver 1: standstill, SG min/max 0/1023
        Driver 2: standstill, SG min/max 0/1023
        Driver 3: standstill, SG min/max 0/1023
        Date/time: 2019-02-09 10:18:35
        Slowest loop: 102.71ms; fastest: 0.06ms
        I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
        Hiccups: 0, StepErrors: 0, LaErrors: 118, FreeDm: 240, MinFreeDm: 148, MaxWait: 166516ms, Underruns: 0, 0
        Scheduled moves: 0, completed moves: 0
        Bed compensation in use: none
        Heater 0 is on, I-accum = 0.1
        Heater 1 is on, I-accum = 0.6
        Segments left: 0
        Stack records: 3 allocated, 0 in use
        Movement lock held by null
        http is idle in state(s) 0
        telnet is idle in state(s) 0
        file is idle in state(s) 0
        serial is idle in state(s) 0
        aux is idle in state(s) 0
        daemon is idle in state(s) 0
        queue is idle in state(s) 0
        Code queue is empty.
        === Network ===
        Slowest loop: 135.87ms; fastest: 0.00ms
        HTTP sessions: 1 of 8
        - WiFi -
        Network state is running
        WiFi firmware version 1.22
        WiFi MAC address 60:01:94:34:3e:4b
        WiFi Vcc 3.38, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 29520
        WiFi IP address 192.168.88.12
        WiFi signal strength -55dBm, reconnections 0, sleep mode modem
      dc42undefined 1 Reply Last reply Reply Quote 1
        dc42 administrators @dragonn
        @dragonn, please make the GCode file available to me and I will look into it.
        • dragonnundefined
          dragonn
          Sure, no problem
          https://www.dropbox.com/s/1rei041f33wfwkb/Tolerance_tester (1).gcode?dl=0
          I also attached my config.g if it will be needed
          0_1549704851966_config (1).g
            Thanks, please leave them there because it will be several days before I can retrieve them.
            Last time LA errors were reported it turned out to be a rounding issue and print quality was not affected.
