Wifi module seems to be dead
Since this morning my wifi module seems to be dead.
I´ve tried flashing firmware again, setting manually wifi parameters, etc, but nothing seems to work.
I´m having the same issues as the user in this thread: https://forum.duet3d.com/topic/3332/cant-get-the-wifi-to-work
I´ve tried everything you suggested in that thread, unsucessfully.Any ideas?
Beyond that, the wifi conection was allways unstable, making uploading files a pain, while my second duet which I bought a month ago works perfectly with the same configuration, same printer and network.
Also, I'm having issues with missing steps in the X axis, happening at the same height in the same file, while the exact same file prints perfectly in my second printer with duet. It not a hardware issue, I've checked that a hundred times.Thanks in advance
Does uploading firmware to the WiFi module using M997 S1 succeed, or not?
@dc42 Hi. Thank tou for your answer.
No, it doesn't work
I think I might need a replacement. I've tried everything but the wifi never turns on
If uploading WiFi firmware using M997 S1 fails with "Could not connect at any speed" then the WiFi module should be replaced. If it fails with a different message, please tell us what the message is.
@dc42 that's the message I got
How should I proceed?
