Cant get the WiFi to Work
  • I was talking on this https://www.duet3d.com/forum/thread.php?pid=31956 thread, but the supplier suggested that I start a new thread so they can see documentation of what has been tried.
    [[language]]
    M122
    Used output buffers: 1 of 32 (8 max)
    RepRapFirmware for Duet WiFi version 1.20beta11 running on Duet WiFi 1.0
    Board ID: 08DDM-9FAM2-LW4S8-6JTDG-3S06T-1MZVX
    Static ram used: 15488
    Dynamic ram used: 97680
    Recycled dynamic ram: 1520
    Stack ram used: 4328 current, 5444 maximum
    Never used ram: 10940
    Last reset 01:05:55 ago, cause: power up
    Last software reset reason: User, spinning module GCodes, available RAM 33032 bytes (slot 2)
    Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
    Error status: 0
    Free file entries: 10
    MCU temperature: min 41.0, current 41.7, max 42.4
    Supply voltage: min 24.3, current 24.5, max 24.5, under voltage events: 0, over voltage events: 0
    Driver 0: standstill
    Driver 1: standstill
    Driver 2: standstill
    Driver 3: standstill
    Driver 4: standstill
    Slowest main loop (seconds): 0.003824; fastest: 0.000042
    MaxReps: 0, StepErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
    Scheduled moves: 0, completed moves: 0
    Bed compensation in use: none
    Bed heater = 0, chamber heater = -1
    Segments left: 0
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is ready with "M122" in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    Network state is disabled
    WiFi module is disabled
    HTTP sessions: 0 of 8
    Socket states:  0 0 0 0 0 0 0 0
    Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
    ok
    ```And this is what happens when i try to set up the wifi, or when i try to upgrade the firmware.
    [[language]]
    M552 s0
    ok
    M552 s1
    Turn off the current WiFi mode before selecting a new one
    ok
    M552 s-1
    WiFi module stopped
    ok
    M552 s1
    ok
    M587 S"Amilious" P"{my pass was here}"
    M587: Failed to add SSID to remembered list
    ok
    M587
    M587: Failed to retrieve network list
    ok
    M552 S-1
    WiFi module stopped
    ok
    ok
    M552 s0
    ok
    M552 s1
    ok
    ok
    M997 S-1
    M997: Invalid module number '-1'
    ok
    M552 S-1
    WiFi module stopped
    ok
    M552 S1
    ok
    ok
    M997 S1
    Trying to connect at 460800 baud: failed
    Trying to connect at 230400 baud: failed
    Trying to connect at 115200 baud: failed
    Trying to connect at 74880 baud: failed
    Error: Installation failed due to comm write error
    ok
    M552 s0
    ok
    M552 s1
    ok
    M552 s-1
    WiFi module stopped
    ok
    M552 s1
    ok
    M997 S1
    ok
  • What have you done leading up to this? I saw in your past posts some comments about changing firmware versions, could you detail what was done with regards to that?
  • I just tried a few different versions to see if it was caused by the firmware. I have tried
    1.18
    1.18.2
    1.19
    1.19.1
    1.19.2
    1.20beta11
    I could not get the wifi to work on any of those firmware versions.
    I just get:
    and
    M997 S1
  • I have had this board since Aug, but I did not try to use it until last week. I had been busy and did not have my printer put together yet. I have built a Hypercube Evolution. Just trying to give any information that may help. It could maybe be something in my config.g as well. I am new to this board and got this config from another thread about a HEVO.
    [[language]]
    M503
    ; Configuration file for Duet WiFi (firmware version 1.17)
    ; generated by RepRapFirmware Configuration Tool on Fri Jun 30 2017 19:04:28 GMT-0500 (Central Daylight Time)
    M111 S0 ; Debugging off
    G21 ; Work in millimetres
    M667 S1 ; Select CoreXY mode
    M208 X300 Y300 Z300 S0 ; Set axis maxima
    M574 X1 Y1 Z1 S1; Define active high microswitches
    M558 P1 X0 Y0 Z0 H5 F120 T6000 ; Set Z probe type to switch, the axes for which it is used and the probe + travel speeds
    G31 P500 X0 Y0 Z2.32 ; Set Z probe trigger value, offset and trigger height
    M557 X13:293 Y5:260 S83 ; Define mesh grid
    M569 P0 S0 ; X goes forwards
    M569 P1 S1 ; Y Reversed
    M569 P2 S0 ; Z goes forwards
    M569 P3 S0 ; Extruder goes forwards
    M92 X99.5 Y99.5 Z399.7 E79.9 ; Set steps per mm
    M566 X900 Y900 Z120 E900 ; Set maximum instantaneous speed changes (mm/min)
    M203 X18000 Y18000 Z500 E1200 ; Set maximum speeds (mm/min)
    M201 X500 Y500 Z250 E250 ; Set accelerations (mm/s^2)
    M906 X1200 Y1200 Z1200 E1200 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M572 D0 S0.1	;Pressure Advance
    M143 S260 ; Set maximum heater temperature to 260C
    ;M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
    M305 P1 T100000 B4725 C7.06e-8 R4700 ; Set thermistor + ADC parameters for heater 1
    M563 P0 D0 H1 ; Define tool 0
    M550 PHYPERCUBE ; Set machine name
    M552 S1 ; Enable network
    ;M587 S"Amilious" P"{my password was here}"; Configure access point and IP addresses. You can delete this line once connected
    M586 P0 S1 ; Enable HTTP
    M586 P1 S0 ; Disable FTP
    M586 P2 S1 ; enable Telnet
    ok
  • Just tried to comment out all the network lines, but got the same result
    @Amilious:
    M997 S1
    If you were using USB power only at the time, try again with VIN power. Otherwise, ask for your Duet to be replaced or repaired - sounds like it needs a new WiFi module.
  • I figured it was probably that. I have read through the forums and that seemed likely to be the problem. I purchased this board on August 11th, and did not take it out of the box until last week. I project got delayed and i was not able to work on it until recently. I have been talking to my supplier(Filastruder). I am waiting for them to get a response from Think3DPrint3D, because I guess I am past the normal time for the exchange. I guess the six month warranty is only after November 14th purchases. The supplier has been very helpful and informative. I'm just a little frustrated because i have been excited to use this board on the HEVO that I have built, that ended up costing twice as much as i originally planed. At least i still have my trusty Anet A8. Ha ha ha. I do have a spare 24V ramps kit laying around, but i hope it does not come to that.
  • I replacement was approved. Thank you for your time and help. I would also like to thank Tim from Filastruder, for his work getting this issue resolved for me.
  • *Tim 😄
  • ha ha ha ha. I knew that, I don't know why i wrote Jim. lol!! Probably because my father is Jim. lol!! Thank you!!!
  • Just got this return, it seems the ESP8266 has developed an internal fault. It gets warm, not too hot to touch but noticeably warm. Can confirm the following:
    SENT: M552
    READ: WiFi module is disabled
    SENT: M552 S1
    READ: ok
    SENT: M552
    READ: WiFi module is being started
    Issuing replacement.
  • I received the fixed or replaced board. I was able to update the firmware and connect to wifi!
  • Hi,
    I've upgraded to 1.21RC2 and I'm encountering the same issue.
    Can't get the board to add the SSID
    • WiFi -
      Network state is starting
    it was working perfectly with 1.19 just before
    [[language]]
    ttyACM1 18°> M115
    SENDING:M115
    FIRMWARE_NAME: RepRapFirmware for Duet WiFi and Duet Ethernet FIRMWARE_VERSION: 1.21RC2 ELECTRONICS: Duet WiFi 1.0 or 1.01 FIRMWARE_DATE: 2018-02-15 build 2
    ttyACM1 18°> M552 S1
    SENDING:M552 S1
    ttyACM1 18°> M589
    SENDING:M589
    M589: Failed to retrieve own SSID data
    Send M552 S-1 to reset the wifi module, then M552 S0. Then send M122 and check what wifi firmware version it reports in the network diagnostics.
  • [[language]]
    Used output buffers: 1 of 32 (1 max)
    RepRapFirmware for Duet WiFi and Duet Ethernet version 1.21RC2 running on Duet WiFi 1.0 or 1.01
    [[language]]
    === Network ===
    - WiFi -
    Can't see the specific WifiServer version
    The WiFi module is stuck on starting. Copy the new DuetWiFiServer.bin file to /sys on the SD card in a PC, then put the card back in the Duet and try installing it using M997 S1 again.
  • yep, sorry for the noise, it's now ok :
    [[language]]
    ttyACM0 17°> M997 S1
    SENDING:M997 S1
     success
    Erasing 4096 bytes...
    Erasing 24576 bytes...
    I should have checked the filesize when I downloaded the bin…
    Thanks !
  • I just tried this or noticed this issue and sent M997 S1 to the board via YAt … wonder if it changes anything
    @lolorc:
    [[language]]
    SENDING:M997 S1
     success
    Thanks !
    Yes, 24576 bytes is about 10% of the correct size.
