    PWM frequency on heater pins used as I/O
    • btw
      btw last edited by
      Hi everyone,
      Is there a way to change the PWM frequency of the heater pins (0-7) when they have been disabled for use as I/O pins?
      Currently I'm following the instructions at:
      https://duet3d.dozuki.com/Wiki/Using_servos_and_controlling_unused_IO_pins
      I am freeing up the heaters for use as I/O pins by disabling them using:
      M307 H# A-1 C-1 D-1
      Then I can then control them using M42. There is an option for frequency in M307 so I'm guessing that the hardware is capable of it, I just can't find an option in the GCode.
      Thanks in advance
      • btw
        btw last edited by
        Just to clarify, I have tried using the M307 F parameter. I don't have a good way of measuring frequency but it doesn't seem to have an impact after the heater has been disabled.
        Is this something that would require a change to the firmware?
          The M42 command has an optional F parameter.
