External drivers are reversing and going forward randomly
So, I've built a little PCB that drives 2 more extruders on the e2 and e3 pins on the expansion connector.
I'm using 2 pololu DRV8825 drivers with all MS pins held high doing x32 microstepping
But, one of the extruders will randomly go backwards or forwards.
What the heck?
@stoop it is probably losing steps. DRV drivers are know for the problems with holding position even when the current is set right.
Try to increase it.
DRV8825 drivers are known for needing very slow step pulse timings. Use the T parameter of the M569 command to extend the timings. Note, this also reduces the maximum possible step rate.
Thanks David.
What would you suggest as a figure?
The datasheet for the DRV8825 will tell you minimum step pulse length, step pulse interval, direction setup time and direction hold time. AFAIR they are about 2.5us.
