    Maestro To WiFi v1.04 SD files
    1.7k
    • Vetiundefined
      Veti @NoSkillzEngineer
      @noskillzengineer
      the maestro has a 2k resistor for thermistors. the wifi 4.7k you need to adjust the thermistor line
      • NoSkillzEngineerundefined
        NoSkillzEngineer
        I didn't realize the WiFi was so much different in that regard. It's the stock Ender 3 thermistor.
        M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
        M305 P0 T100000 B4138 C0 R2200 ; Set thermistor + ADC parameters for heater 0
        M307 H1 B0 S1.00
        M305 P1 T100000 B4725 C0 R2200 ; Set thermistor + ADC parameters for heater 2
        What would I have to change and to what would I have to change it to? My thermostat says my temperature is 73° F or about 22.7/22.8
          Change R2200 to R4700, or leave out the R parameter altogether so that it uses the default value for the board.
          NoSkillzEngineerundefined 1 Reply Last reply Reply Quote 0
            NoSkillzEngineer @dc42
            @dc42 Leaving it out entirely resulted in 23.5 degrees celsius which is 74.3 degrees, thank you so much for your help! 🙂 I'll remember that from now on.
