    Connecting 5V optical encoders to endstop inputs
    • mildw4veundefined
      mildw4ve
      Can 5V optical encoders be used to measure filament flow? I tried connecting them to E0 endstop input with a 3.3V endstop power but the encoder doesn't work at such low voltage, it needs ~4V minimum.
      Is it safe to connect the encoder to a 5V pin on either the DUET or DUEX?
      • Vetiundefined
        Veti
        only revision 1.04 of the duet
        https://duet3d.dozuki.com/Wiki/Hardware_Overview#Section_PCB_revision_v1_Num_04
          Please provide details of the encoder. It may be possible to run it from 3.3V by changing one resistor.
          • mildw4veundefined
            mildw4ve
            I do have a Duet 2 Ethernet v1.04
            The encoder is a Kuebler 2430
            https://www.kuebler.com/k2014/j/en/produkte/details/drehgeber/Inkremental/2430
            Technical Data
            Shaft Type Shaft
            Dimension Ø 24 mm
            Flange Ø 24.00 mm
            Ø 28.00 mm
            Ø 30.00 mm
            Connection Cable radial
            Cable axial
            Protection max IP67
            Working temperature -20° C ... +85° C
            Speed max. 12.000 min-1
            Supply voltage 5 VDC
            Interfaces RS422
            Resolution max: 256 ppr | Incremental
              Looks like you will need to power it from 5V, which you can get from the expansion connector or from the PanelDue connector. You can feed the output directly into an endstop input of your rev. 1.04 Duet.
