    Duet Wifi web control possible issue
    • Prawnabieundefined
      Prawnabie
      Hi all,
      Just setting up my unwired Duet wifi for the first time, have got it connected to my router and edited the config.g file to permanently enable the wifi server and all is good. The only issue I seem to have is that the window that the web control is in is named "minikosselwebcontrol". this is also displayed in the web control screen itself. I am sure I am not in any "test" mode, but as the board is lay on the desk with nothing connected to check I just need a sanity check!
      If it makes a difference I haven't yet uploaded anything to it apart from a couple of instructions for the web server.
      Thanks,
      Shaun
        I suggest you use the System Editor function in the web interface to open the config.g file, and check the machine name in the M550 command.
