Missing spindles in M408 response?
  • I'm experimenting with controlling a spindle from Duet. I've switched the machine to CNC mode with M453 P22 R24000 F100, and the PWM output works as it should when I send M3 commands. Cool.
    However, I'm not seeing spindle info in the reply from M408. The source code indicates that there should be a "spindles" entry in the JSON data, but I'm not seeing it. M450 confirms that the mode is PrinterMode:CNC.
    The other condition the firmware checks for is that the spindle tool number isn't -1. This is difficult for me to verify, but it doesn't work even if I explicitly pass a T parameter to M453.
    What am I missing? How do I get spindles included in M408?
    FWIW, here's my config.g (no actual steppers or anything are actually connected, so this is mostly from RRF Config Tool):
    G90                                      ; Send absolute coordinates...
    M83                                      ; ...but relative extruder moves
    M550 P"My CNC"                       ; Set machine name
    M552 S1                                  ; Enable network
    M586 P0 S1                               ; Enable HTTP
    M586 P1 S0                               ; Disable FTP
    M586 P2 S0                               ; Disable Telnet
    M569 P0 S1                               ; Drive 0 goes forwards
    M569 P1 S1                               ; Drive 1 goes forwards
    M569 P2 S1                               ; Drive 2 goes forwards
    M569 P3 S1                               ; Drive 3 goes forwards
    M350 X16 Y16 Z16 E16 I1                  ; Configure microstepping with interpolation
    M92 X80.00 Y80.00 Z4000.00 E420.00       ; Set steps per mm
    M566 X900.00 Y900.00 Z12.00 E120.00      ; Set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z180.00 E1200.00  ; Set maximum speeds (mm/min)
    M201 X500.00 Y500.00 Z20.00 E250.00      ; Set accelerations (mm/s^2)
    M906 X800.00 Y800.00 Z800.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30                                  ; Set idle timeout
    M208 X0 Y0 Z0 S1                         ; Set axis minima
    M208 X230 Y210 Z200 S0                   ; Set axis maxima
    M574 X1 Y1 S1                            ; Set active high endstops
    M574 Z1 S2                               ; Set endstops controlled by probe
    M558 P1 H5 F120 T6000                    ; Set Z probe type to unmodulated and the dive height + speeds
    G31 P500 X0 Y0 Z2.5                      ; Set Z probe trigger value, offset and trigger height
    M557 X15:195 Y15:195 S20                 ; Define mesh grid
    M140 H-1                                 ; Disable heated bed
    M563 P0 D0 H                             ; Define tool 0
    G10 P0 X0 Y0 Z0                          ; Set tool 0 axis offsets
    G10 P0 R0 S0                             ; Set initial tool 0 active and standby temperatures to 0C
    ; CNC
    M106 P2 I-1
    And here's the output from M408 S2:
       "status":"O",
       "coords":{
          "axesHomed":[
             0,
             0,
             0
          "xyz":[
             0.000,
             0.000,
             0.000
          "machine":[
             0.000,
             0.000,
             0.000
          "extr":[
             0.0
       "speeds":{
          "requested":0.0,
          "top":0.0
       "currentTool":-1,
       "params":{
          "atxPower":0,
          "fanPercent":[
             0,
             100,
             0,
             0,
             0,
             0,
             0,
             0,
             0
          "speedFactor":100.0,
          "extrFactors":[
             100.0
          "babystep":0.000
       "sensors":{
          "probeValue":205,
          "fanRPM":0
       "temps":{
          "current":[
             2000.0,
             2000.0,
             2000.0,
             2000.0,
             2000.0,
             2000.0,
             2000.0,
             2000.0
          "state":[
             0,
             0,
             0,
             0,
             0,
             0,
             0,
             0
          "tools":{
             "active":[
                   0.0
             "standby":[
                   0.0
          "extra":[
                "name":"*MCU",
                "temp":41.2
       "time":1697.0
    Which firmware version are you using?
  • @dc42 said in Missing spindles in M408 response?:
    2.02(RTOS) (2018-12-24b1)
  • Any troubleshooting tips for this? Since the PWM output works, it seems to me that it should be set up properly and M408 should include the spindle data.
    I'd like to poll M408 and get the RPM from there (and set my VFD frequency over Modbus accordingly) instead of relying on PWM. I got an Arduino to measure the PWM with interrupts, but it wasn't as precise as I'd like.
    Please can you upgrade to 2.03beta2 and try again.
    @dc42 Okay, done. It's still the same. PWM output works, but no "spindles" entry in M403 response. 😕
    {"status":"O","coords":{"axesHomed":[0,0,0],"xyz":[0.000,0.000,0.000],"machine":[0.000,0.000,0.000],"extr":[0.0]},"speeds":{"requested":0.0,"top":0.0},"currentTool":-1,"params":{"atxPower":0,"fanPercent":[0,100,0,0,0,0,0,0,0],"speedFactor":100.0,"extrFactors":[100.0],"babystep":0.000},"sensors":{"probeValue":205,"fanRPM":0},"temps":{"current":[2000.0,2000.0,2000.0,2000.0,2000.0,2000.0,2000.0,2000.0],"state":[0,0,0,0,0,0,0,0],"tools":{"active":[[0.0]],"standby":[[0.0]]},"extra":[{"name":"*MCU","temp":41.2}]},"time":196.0}
  • Hey, if I pass a T value to M453, it actually works now. That's nice, but not exactly obvious, especially since the T parameter isn't even documented (afaik).
    Oh well, I'm happy for now. Thanks for your help!
    I didn't write the extension that allows different tools to have different spindles. It looks like S is the spindle number (default 0) and T is the tool number to assign the spindle to, default -1. Only spindles assigned to tools are listed in the M408 response.
