Z-Probe
    On the DWC, under Z-Probe, previously it was just "0". Suddenly it has become "0 (0)" and when I put something near the sensor, the reading becomes "0 (535)", and my Z-probe doesn't stop.
    Any hints?
  • uhh, it's ok! I figured. in Config.g it should have been M558 P1 but the configurator generated it as M558 P2 😞
    Been having quite a bit of issues with the codes generated by the configurator actually. For example, homing my Z axis to the high end, it moves the Z towards the high end but sets the Z position to minimum after homing.
    @pinkmaro said in Z-Probe:
    If you are homing to the high end, you must be using an endstop switch for Z homing, not a Z probe. In the configurator change the Z axis endstop from "Low end" to "high end". Or in the M574 command that it generated in config.g, change Z1 to Z2.
  • Sorry if i was being confusing.
    It was 2 separate issues.
    First issue:
    I have set up for 1 Z-probe and initially it was working fine (i.e. Z-probe was set as P1 in config.g).
    I did change other stuff in the configurator tool but I didn't change anything about the Z-Probe but starting from some point, the Z-probe was generated as P2 instead of P1.
    The code in config.g was:
    M558 P2 H5 F120 T6000 ; Set Z probe type to modulated and the dive height + speeds
    G31 P500 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
    M557 X0:1050 Y-1040:0 S20 ; Define mesh grid
    Second issue: I have defined my Z-axis homing with a limit switch to the "High End" but consistently my homez.g was as follow:
    ; homez.g
    ; called to home the Z axis
    ; generated by RepRapFirmware Configuration Tool v2 on Fri Feb 22 2019 13:32:37 GMT+0800 (Singapore Standard Time)
    G91 ; relative positioning
    G1 S1 Z1062.35 F1800 ; move Z up until the endstop is triggered
    G92 Z1 ; set Z position to axis minimum (you may want to adjust this)
    ;G91 ; relative positioning
    ;G1 S2 Z5 F100 ; lift Z relative to current position
    ;G90 ; absolute positioning
    Initially I was really fresh to this whole 3D printing, Duet, Reprap and all these G-codes. But now I'm starting to understand better and so I know where to check for problems, and I can make the adjustments, so no big issue.
    Hope this clarifies my confusing post earlier.! ^^
    Ok, so you need P1 in your M558 command; and for homing Z to high end you should not have a G92 command after the Z homing move. Use M208 to define the Z position at the endstop instead.
  • Your post always enlightens me on something new! I didn't know about M208!! Thank you! will go and change my code ^^ cheers
