Strange auto calibrate map and heights
  • Hello everyone,
    So I am going through the config.g trying to sort out everything in my other post (Here).
    I am getting a strange bed auto calibrate map. Not sure what I have done, I changed the micro stepping from x32 to x16 as it was pointed out to me that x32 does not work. The delta is so smooth now, and according to the callipers moving the right distance.
    Please see attached image, I have never seen such a massive curve across the bed. As ever all help extremely appreciated.
    Best,
    Andy
    Config.g
    ; Configuration file for Duet Ethernet (firmware version 1.17)
    ; generated by RepRapFirmware Configuration Tool on Mon May 22 2017 22:56:20 GMT-0400 (Eastern Daylight Time)
    M111 S0 ; Debugging off
    G21 ; Work in millimetres
    M555 P1 ; Set firmware compatibility to look like RepRapFirmare
    M665 R150 L397.19 B155 H525 ; Set delta radius, diagonal rod length, printable radius and homed height
    M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
    M208 Z0 S1 ; Set minimum Z
    M574 X2 Y2 Z2 S1 ; Define active high microswitches
    M558 P1 X0 Y0 Z0 H5 F500 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
    M557 R150 S30 ; Define mesh grid
    ; BL-Touch
    M307 H3 A-1 C-1 D-1 ; reserve pin 21 for M42 or servo use
    M558 P9 X0 Y0 Z0 H30 F2500 T5000 ;P9 is a key BLTouch Value
    G31 P25 X0 Y0 Z1.5 ; Set Z probe trigger value, offset and trigger height
    M350 E16 I0 ; Configure microstepping without interpolation
    M350 X16 Y16 Z16 I1 ; Configure microstepping with interpolation
    ;M92 X160 Y160 Z160 E1763 Set steps per mm for x32
    M92 X80 Y80 Z80 E838 ;E1763 Set steps per mm for x16
    M566 X2000 Y2000 Z2000 E2000 ; Set maximum instantaneous speed changes (mm/min)
    M203 X2500 Y2500 Z2500 E2500 ; Set maximum speeds (mm/min)
    M201 X2500 Y2500 Z2500 E2500 ; Set accelerations (mm/s^2)
    M906 X1800 Y1800 Z1800 E1500 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M143 S285 ; Set maximum heater temperature to 285C
    M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
    M305 P0 T100000 B4607 C8.950070e-8 R4700 ; Set thermistor + ADC parameters for heater 0
    M305 P1 T100000 B4725 C0 R4700 ; Set thermistor + ADC parameters for heater 1
    ;M307 H1 A330.8 C243.9 D1.8 B0
    M563 P0 D0 H1 ; Define tool 0
    M207 S1.8 R1.8 F3000 T3000 Z0.5 ; Set FW retraction length and speed
    M572 D0 S0.05 ; Set pressure advance
    ;Pressure Advance M572 D0 S0.04
    M550 PTEVO Little Monster ; Set machine name
    M540 PBE:EF:DE:AD:FE:ED ; Set MAC address
    M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
    M586 P0 S1 ; Enable HTTP
    M586 P1 S0 ; Disable FTP
    M586 P2 S0 ; Disable Telnet
    M106 P1 S0 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P2 S0 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M501 ;Load saved parameters from non-volatile memory
    You have a delta printer but you haven't calibrated it. See https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer.
