    Duet2 Ethernet not responding after reboot/reset
    1.1k
    • clegg78undefined
      clegg78
      Hi there,
      I am new to Duet, but I think I've done some solid troubleshooting on this. I have a Duet2 Ethernet. Everything worked fine, but once I updated the firmware to 2.02a (I only used the board a few times on USB before updating as I just received it and not with the ethernet connected) after a reboot the Ethernet component will just be static.
      This is a Duet2 Ethernet + Duex5
      Green and yellow LED's solid, no blinking. I've done M552 S0 then S1 to reset the port, nothing. I've pulled the cable out and let it sit for a dozen seconds and put it back in, and nothing.
      If I power it off for an extended period (5+ minutes) the port will come back online and work fine until I do anything that causes a reboot of the board. After that point the ethernet port will remain dead.
      This is on 12V and when on USB.
      Do I have a bum Ethernet controller board on this brand new Duet2? Looks like an easy swap to replace if so, but this is frustrating.
      The network config is: ; Network
      M550 P"Joes Printer" ; Set machine name
      M551 P"a password" ; Set password
      M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
      M586 P0 S1 ; Enable HTTP
      M586 P1 S1 ; Enable FTP
      M586 P2 S1 ; Enable Telnet
      The networking setup here is all running managed enterprise hardware, so there should be no issue with that. There are no port errors, the port is just not active when its in this state.
      I would prefer DHCP, but if I need to try static I can do that too.
      Note, when I did the firmware update, I may have accidentally run "M997 S1 " as part of it instead of S0. Not sure if this could be the issue.
      A geek designing and building his own custom IDEX printer from scratch as seen here: https://joekelly.co/3d/
      • clegg78undefined
        clegg78
        I've changed it to static IP to see if anything is different, and no it is not.
          Are you providing VIN power, or just USB power?
          If you send M122 from USB when it won't connect, what does the Network section of the diagnostic report show?
          If you don't set a static IP address, does M552 report an assigned IP address, or not?
          dc42undefined 2 Replies Last reply Reply Quote 0
          • clegg78undefined
            clegg78
            M122 reports:
            M122<CR>
            RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet Ethernet 1.02 or later + DueX5
            Board ID: 08DGM-9T6BU-FG3SN-6JKF2-3S46Q-1UY7D
            Used output buffers: 1 of 20 (2 max)
            Static ram: 25524
            Dynamic ram: 98440 of which 0 recycled
            Exception stack ram used: 272
            Never used ram: 6836
            Tasks: NETWORK(ready,1612) HEAT(blocked,1324) MAIN(running,3868) IDLE(ready,200)
            Owned mutexes:
            Last reset 00:00:32 ago, cause: power up
            Last software reset at 2019-02-23 17:48, reason: User, spinning module GCodes, available RAM 6736 bytes (slot 3)
            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
            Error status: 0
            Free file entries: 10
            MCU temperature: min 16.9, current 19.1, max 19.2
            Supply voltage: min 0.4, current 0.4, max 0.7, under voltage events: 0, over voltage events: 0, power good: no
            Driver 0: ok, SG min/max not available
            Driver 1: ok, SG min/max not available
            Driver 2: ok, SG min/max not available
            Driver 3: ok, SG min/max not available
            Driver 4: ok, SG min/max not available
            Driver 5: ok, SG min/max not available
            Driver 6: ok, SG min/max not available
            Driver 7: ok, SG min/max not available
            Driver 8: ok, SG min/max not available
            Driver 9: ok, SG min/max not available
            Cache data hit count 66505232
            Slowest loop: 0.99ms; fastest: 0.06ms
            I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
            Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
            Scheduled moves: 0, completed moves: 0
            Bed compensation in use: none
            Segments left: 0
            Movement lock held by null
            http is idle in state(s) 0
            telnet is idle in state(s) 0
            file is idle in state(s) 0
            serial is ready with "M122" in state(s) 0
            aux is idle in state(s) 0
            daemon is idle in state(s) 0
            queue is idle in state(s) 0
            Code queue is empty.
            === Network ===
            Slowest loop: 0.39ms; fastest: 0.02ms
            HTTP sessions: 0 of 8
            Interface state 5, link 100Mbps full duplex
            ok
            and M552 Returns:
            M552
            Network is enabled, configured IP address: 192.168.50.45, actual IP address: 192.168.50.45
            ok
            But the Green LED is just locked steady with no movement, and I cant access the device. If I power it off for an extended period of 2-5 minutes it will come back and work when I power it up.
              dc42 administrators @dc42
              @dc42 said in Duet2 Ethernet not responding after reboot/reset:
              clegg78undefined 1 Reply Last reply Reply Quote 0
                Your M122 report indicates you are only supplying USB power. That may not be sufficient.
                and:
                • clegg78undefined
                  clegg78
                  It does it on 12V VIN as well... but I can connect it to the PSU ,and run the M122 again... I've primarily only used it on VIN supply. Just for this I had to disconnect it to get it over to my PC.
                  • clegg78undefined
                    clegg78 @dc42
                    @dc42 if I dont set an assigned IP: If it is working, it will report an IP via DHCP, if its not, it wont. It lists no IP or 0.0.0.0
                      dc42 administrators @clegg78
                      @clegg78 said in Duet2 Ethernet not responding after reboot/reset:
                      I suspect a temperature-related fault on the Ethernet board, so I suggest you ask your supplier to swap the Duet for another.
                      • clegg78undefined
                        clegg78
                        Thanks, I've submitted an RMA with the place I bought it.
                        I also dont think its temperature related, I can power up the board, and wait 15 seconds ( or how ever long it takes for it to fully boot) , hit the reset button, and the ethernet board is dead then until it powers down for a minute or two
                        • clegg78undefined
                          clegg78
                          Just to follow up, I received my replacement Duet2Ethernet and it works perfect. The last one had issues updating the firmware from the web interface, and the lock up issue with the ethernet in general. The new one is working perfectly as expected.
                          Thanks for the troubleshooting assistance.
                            Thanks for confirming this. I'm sorry that you received a faulty Duet.
