    DWC access IP
    Duet Web Control
    • peirof
      peirof last edited by
      since 2 days i cant access to DWC in the established IP in config.g, i have:
      M550 PTLM Duet 2B ; Set machine name
      M587 S"TERRAZAExtender2.4GHZ" P"a1b2c3d4" I192.168.1.200
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      Now, the acces IP to DWC 192.168.1.113, i dont have config-override
        Remove the M587 command from config.g. it should not be in there. The command needs to be sent only once because the details are stored on the WiFi module.
        Send M587 without parameters to list the access points that the WiFi module knows about and the IP addresses it requests.
        • peirof
          peirof last edited by peirof
          i have do some tests....
          how i can force, that Duet connects to one of the networks stored??
          If i send M587, by console, Duet respond with 4 wifi networks, and i d'like connect to one of them.... but it connects to another...
           M587
           Remembered networks:
           TNCAP2FCC19 IP=192.168.1.14 GW=0.0.0.0 NM=0.0.0.0
           DIR869l-2,4 IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
           DIR869L-2,4 IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
           TERRAZAExtender2.4GHZ IP=192.168.1.200 GW=0.0.0.
          I d'like to connect to the last.... i have do a macro:
           M552 S0 ;Desactiva el WiFI
           M587 S"TERRAZAExtender2.4GHZ" P"a1b2c3d4" I192.168.1.200 ;Establece el punto de conexion
           M552 S1 ;Activa el WiFi
           M587 ;Guarda los datos de conexion en el modulo Wifi
          but....
          M552
          WiFi module is connected to access point DIR869L-2,4, IP address 192.168.1.112
          Duet connects to another router.....
          • DocTrucker
            DocTrucker last edited by DocTrucker
            The P parameter of M552 can tell it what network to use from the list previously stored onto the wifi using M587.
            Use M588 to delete networks.
            I've not got a wifi to test this on, just searched the gcode guide: https://duet3d.dozuki.com/Wiki/Gcode
            Alive: 1 Ormerodish machines. 1 Custom Cantilever. 3 P3Steel. 1 Ciclopish scanner. In build: 1 P3Steel. Controllers: 2 Duet 2 , 2 D0.6, 1 D0.8.5, 1 D3 v0.5, 1 RAMPS/DRV8825, 1 Uno/Scan Card.
