    Monoprice Select Plus - Duet wiring
    696
    • mfisher103undefined
      mfisher103
      Is there a how to for wiring a Duet Ethernet to a Monoprice Select Plus?
        A search of the forum for "Monoprice Select Plus" yielded only your post, so I think the answer is no. If you provide details of the wiring to the original controller (e.g. photos) then we'll try to help you.
        mfisher103undefined 3 Replies Last reply Reply Quote 0
          mfisher103 @dc42
          @dc42 Thanks for your reply. It is the same printer as the Wanhao i3 Plus if that helps.
            mfisher103 @dc42
            @dc42 I did just find this....Wiring Help Request: Wanhao i3 Plus (16-Pin IDC)
              mfisher103 @dc42
              @dc42 I guess the other option would be to run all separate wires from where the ribbon cable goes into the block where the extruder is....I think this might be better as it would prove a separate ground for each thing... So I would have 5 separate wires....what do you think?
                Sharing the + wire between the heater and the fan is OK. Sharing the ground wire between the thermistor and the fan is not.
                What is the connector at the bottom right for? I can't read the label.
                mfisher103undefined 1 Reply Last reply Reply Quote 0
                  mfisher103 @dc42
                  @dc42 It's the X stop....That why I think it better to get rid of the ribbon cable and just wire each thing direct...
                    You could wire the thermistor direct and leave the rest as-is.
                      mfisher103 @dc42
                      @dc42 Ok thanks
