    NTC100k or PT1000 as bed temp sensor
    • paboman
      paboman last edited by
      which temperature sensor is better for the bed considering the price is nearly the same? I can choose the standard NTC100k or a PT1000 class B
      Datasheet_PT1000.pdf
        For a bed heater, either is adequate. The thermistor will give you higher resolution. The PT1000 may give you better accuracy, especially if you don't have a resistance vs temperature table for the thermistor.
