    G29 leveling inconsistency (not z readings but actual function)
    • 3dprinting meathead
      3dprinting meathead last edited by
      The first time I tried to run g29, it came up with a warning that no bed area was defined. the next time it ran 80 points. then it ran 24(about), then 9, then 30 for a few times, then another area not defined, then back to 30.
      I know I don't have to run it this much, but I did it a few(many) times because I kept on getting weird codes or different areas measured.
      I'm running 1.17e, i3 clone with bltouch.
      Here's my g29 macro, does anyhing stand out that might be causing this?
      G28
      G91
      G1 Z4 F300
      G90
      M98 Pdeployprobe.g
      G29 S2
      G29
      M557 X0:200 Y0:200 S40
      M98 Pretractprobe.g
      G1 X10 Y10 F5000
      Thanks for the help!
      If I can learn it, than anyone can learn it.
      • Jackal
        Jackal last edited by
        Your M557 command should come before G29
          @Jackal:
          Thanks, I'll try that tomorrow.
