Solved Unable to ''connect'' to duet server after re-installing FW
I am unable to connect to duet server. I erased my SD card, reinstalled latest firmware and duet server. However, I am unable to ''connect'' to wifi server. Whenever I click ''connect'' on the IP, nothing happens.This is my log from YAT
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.02 or later
Board ID: 08DGM-956GU-DJMSJ-6J9DL-3SN6R-TTQ3F
Used output buffers: 1 of 20 (10 max)
Static ram: 25524
Dynamic ram: 98124 of which 0 recycled
Exception stack ram used: 312
Never used ram: 7112
Tasks: NETWORK(ready,836) HEAT(blocked,1232) MAIN(running,3776) IDLE(ready,200)
Owned mutexes:
Last reset 00:06:55 ago, cause: reset button or watchdog
Last software reset at 2019-03-01 18:11, reason: User, spinning module GCodes, available RAM 6664 bytes (slot 2)
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
Error status: 0
Free file entries: 10
MCU temperature: min 40.5, current 42.5, max 43.4
Supply voltage: min 24.3, current 24.4, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
Cache data hit count 1357433627
Slowest loop: 100.08ms; fastest: 0.08ms
I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
Scheduled moves: 0, completed moves: 0
Bed compensation in use: none
Segments left: 0
Stack records: 0 allocated, 0 in use
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is ready with "m122" in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 23.05ms; fastest: 0.00ms
HTTP sessions: 0 of 8- WiFi -
Network state is running
WiFi firmware version 1.22
WiFi MAC address 5c:cf:7f:76:6e:c8
WiFi Vcc 3.39, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 29640
WiFi IP address 192.168.1.7
WiFi signal strength -72dBm, reconnections 0, sleep mode modem
ok
- WiFi -
@cozyp said in Unable to ''connect'' to duet server after re-installing FW:
Your wifi connection is very weak.
See here for some tips on improving it: https://duet3d.dozuki.com/Wiki/WiFi_disconnections_and_AJAX_timeout_errors
the thing is, that it was working before. Can't do anything about the weak signal, I am already using a signal extender....
Check the images of the web interface, seems weird... -
Perhaps you should reupload the DWC files.
https://github.com/dc42/RepRapFirmware/releases/download/2.02/DuetWebControl-1.22.6.zip
@phaedrux I erased the firmware and tried to re-install the beta one, but bumped in the most common error.
combined2firmware.bin not found......
Let me solve that annoying error first and will re-try -
@Phaedrux yes, it worked...... CASE CLOSED
