    Duetwifi disconnects due to onedrive updating
    1
    163
    • percar
      percar last edited by
      I have recently discovered one reason for Duetwifi disconnects. It appears that when OneDrive does an update of the files it utilizes most of the bandwidth that you have available especially if band width is slow like I have. When OneDrive takes over the bandwidth duet wifi disconnects for the server.
      If you are using your duet wifi then you can do a pause on the onedrive service or stop it all together.
